Budget (including currency): $2300ish
Country: USA
Games, programs or workloads that it will be used for: Some shooters, rpgs, possibly mmos, internet, office apps, no video editing/rendering
Other details (existing parts lists, whether any peripherals are needed, what you're upgrading from, when you're going to buy, what resolution and refresh rate you want to play at, etc): This will be the 3rd pc I've built and it's been a few years. Looking to get 4-5 years out of this build. I've already got monitor, mouse, keyboard. Current pc is quite old. i5-6500 @3.20GHz, 16GB RAM, GeForce GTX 1070. Basically does this have any glaring faults and any helpful advice is much appreciated.
My Build
https://linustechtips.com/topic/1519149-help-with-my-build/
Just a few changes: o/s, faster AMD Expo RAM, 850W psu (min for that gpu), a conventional case with much better airflow, cpu cooler that won't be impacted by a board with large heatsinks and a SATA SSD so that you aren't sucking up the PCIe lanes with two M.2 SSD's.
PCPartPicker Part List
CPU: AMD Ryzen 7 7800X3D 4.2 GHz 8-Core Processor  ($439.00 @ Newegg)
CPU Cooler: *Deepcool AK620 68.99 CFM CPU Cooler  ($51.19 @ Amazon)
Motherboard: Gigabyte B650 AORUS ELITE AX ATX AM5 Motherboard  ($199.99 @ Amazon)
Memory: *G.Skill Flare X5 32 GB (2 x 16 GB) DDR5-6000 CL36 Memory  ($94.99 @ Amazon)
Storage: Samsung 970 Evo Plus 2 TB M.2-2280 PCIe 3.0 X4 NVME Solid State Drive  ($79.98 @ Amazon)
Storage: *Samsung 870 Evo 2 TB 2.5" Solid State Drive  ($99.99 @ Adorama)
Video Card: XFX Speedster MERC 310 Black Edition Radeon RX 7900 XTX 24 GB Video Card  ($904.99 @ Newegg)
Case: *Lian Li LANCOOL 216 ATX Mid Tower Case  ($92.99 @ Adorama)
Power Supply: *MSI MPG A850G PCIE5 850 W 80+ Gold Certified Fully Modular ATX Power Supply  ($109.99 @ Newegg)
Operating System: *Microsoft Windows 11 Home OEM - DVD 64-bit  ($99.99 @ Newegg)
Total: $2173.10
Generated by PCPartPicker 2023-07-13 02:54 EDT-0400
https://lian-li.com/product/lancool-216/
https://www.msi.com/Power-Supply/MPG-A850G-PCIE5
https://www.deepcool.com/products/Cooling/cpuaircoolers/AK620-High-Performance-CPU-Cooler-1700-AM5/2021/13067.shtml
https://www.xfxforce.com/shop/xfx-speedster-merc-310-7900xtx-black-edition#2
Minimum Power Supply Requirement: 850W
https://linustechtips.com/topic/1519149-help-with-my-build/#findComment-16031466
5 hours ago, Why_Me said:
Once the 6000C30 and 5600C28 version goes back in stock, id replace it with that. And also other board OP can consider:
https://pcpartpicker.com/product/YZgFf7/gigabyte-b650-gaming-x-ax-atx-am5-motherboard-b650-gaming-x-ax 170 USD (currently out of stock)
https://pcpartpicker.com/product/ckhFf7/asrock-b650-livemixer-atx-am5-motherboard-b650-livemixer 170 USD (best connectivity per dollar out of all B650 boards, but super ugly)
https://pcpartpicker.com/product/CFzhP6/msi-pro-b650-p-wifi-atx-am5-motherboard-pro-b650-p-wifi 180 USD
https://pcpartpicker.com/product/wkFbt6/msi-mpg-b650-edge-wifi-atx-am5-motherboard-mpg-b650-edge-wifi 240 USD (currently out of stock)
Press quote to get a response from someone! | Check people's edited posts! | Be specific! | Trans Rights
https://linustechtips.com/topic/1519149-help-with-my-build/#findComment-16031744
CPU Cooler: Thermalright Peerless Assassin 120 SE ARGB 66.17 CFM CPU Cooler  ($37.90 @ Amazon)
Memory: G.Skill Trident Z5 Neo RGB 32 GB (2 x 16 GB) DDR5-6000 CL30 Memory  ($109.99 @ Amazon)
Storage: Samsung 970 Evo Plus 2 TB M.2-2280 PCIe 3.0 X4 NVME Solid State Drive  ($105.76 @ Amazon)
Video Card: Sapphire NITRO+ Radeon RX 7900 XTX 24 GB Video Card  ($999.99 @ Newegg)
Case: Lian Li PC-O11 Dynamic ATX Full Tower Case  ($119.99 @ B&H)
Power Supply: Corsair RM1000x (2021) 1000 W 80+ Gold Certified Fully Modular ATX Power Supply  ($159.99 @ Newegg)
Total: $2278.37
Generated by PCPartPicker 2023-07-13 11:23 EDT-0400
Changed it around a bit to eek out a bit more performance. The main difference - memory is now 6000MHz CL30 one with EXPO, which is the best memory for 7800X3D. Change the 7900XTX to the best one there is - the Nitro+ and updated the PSU to 1000W. 850W is the absolute minimum you shouldn't go under. Also removed the ridiculously expensive Windows - just get a normal $12-$15 one from any retailer site like kinguin or cdkeys. $100+ is absurd.
| Ryzen 7 5800X3D | Arctic Liquid Freezer II 360 Rev 7| AsRock X570 Steel Legend |
| 4x16GB G.Skill Trident Z Neo 4000MHz CL16 | Sapphire Nitro+ RX 6900 XT | Seasonic Focus GX-1000|
| 512GB A-Data XPG Spectrix S40G RGB | 2TB A-Data SX8200 Pro| Phanteks Eclipse G500A |
https://linustechtips.com/topic/1519149-help-with-my-build/#findComment-16031971
