Is this problem worth repairing?
Go to solution Solved by Dedayog,
5 minutes ago, sloosysinate said:
Update!
It has a straight green line in the middle, had a similar problem with the last monitor that ran 5 years like that.
They are also giving words of 1-year warranty repairing, which I don't know how they can keep, if they move their shop or just ghost me somehow.
Still plan to somewhat have evidence that they did assure me of at least 1-year warranty, I'll bargain for 2 years.
When I asked if the one green line might multiply! They said lines can multiply if it's moved to much. Is that a red flag?
What do you guys think?
I think you need to buy a decent monitor and take care of it.
Otherwise, I am not sure how you can expect a 2 year warranty which is longer than the actual manufacturers warranty usually!
If the green line is the best you can get, then take it, pay him and save up for a real monitor.
This picture is actually used for reference because I didn't get mine. My monitor is Asus VZ279HE! About 25 days ago, one fine day I had this similar problem you see in picture. I tried the monitor on other PCs, all had the same white screen problem. I was distraught, cause my warranty finished last year. I didn't waste any time, rushed to monitor repairing shop. They asked me for 2 days, I gave them. They failed to repair it! I was seeing then glitchy white screens. Maybe he really broke it!?
Then I handed it over to one of my trusted, tech brother. He sent it to someone real expert. Now they repaired it! But they want 60+ dollars something and I get no warranty if it breaks down or happens anything. This is where I want some real suggestions!
If I pay them 60 dollars for no warranty! Why don't I save some and buy a new one with 140 dollars and have a 2-3 years warranty!?? Even though It's really hard to save money, or take this loan from family.
One more thing, my first PC monitor was 40-50 bucks. It also broke within like few months in 2017! I repaired it then with like $18, and it ran till last year. So I have a sense if electronic stuff doesn't get damaged severely, if I repair it it will run well as long as it can. I would have taken the risk if it was again this small but 60+ is just too much to risk!
https://linustechtips.com/topic/1518646-is-this-problem-worth-repairing/
by all accounts it is a decent 1080p monitor and if it is fixed I see no reason not to just pick it up from the repair.
i expect they replaced a daughter card for the display itself as white sceen simply means it is powering ok and the backlight is ok just the dispaly signal itself was screwed up.
I think you were just unlucky as I have monitors that still work from 2007 just use them now and again for some tasks if I need a quick solution for something.
That's life, the guy will spend time and parts to repair your monitor and it costs money
No reason he gives you any warranty...
If you don't repair it you're stuck with useless ewaste junk and have to buy another monitor
Your choice
If that person already performed the job, pay them man. He spent the time and did the fix. Next time it breaks, buy a new monitor.
If the monitor backlight is like in the picture, it's time for a new monitor.
The monitor in the picture uses CCFL tubes to produce the light, these are like long thin neon tubes on the bottom and top of the screen.  When the tubes get old and wear out, the ends get a brown tint to them, and the backlight gets a cream/brownish color at the edges of the screen.
As the tubes degrade, they consume more power and at some threshold, the backlight circuit on the power supply board inside the monitor will refuse to start the backlight due to too high power consumption.
I  think you owe the man $60.  He fixed it, you owe.  Simple.  Now maybe you should have asked what it would cost before having him fix?
Most repair shops won't give warranty, as they can't control the rest of the item and there isn't a clear way to isolate their fix vs other things.  If it breaks again, how can you prove it was THEIR fix that died?
Either way, PC's aren't always cheap as you're finding out.  Sorry man, but pay the man.
Onyx: Ryzen 7 7800X3D / Gigabyte B650 AORUS Pro AX / ASRock Taichi 7900xtx OC / G. Skill Flare X5 6000CL36 64GB (4x16GB) / Samsung 980 1TB x3 / Super Flower Leadex V Plat Pro 1000 / EK-AIO 360 Basic w/ Silent Wings fans / Fractal Design North XL (black mesh) / LG - UltraGear 45" OLED QHD 240Hz / Mackie CR5BT / SteelSeries Arctis Nova Pro / Cherry MX Board 3.0 / Logitech G502 - https://valid.x86.fr/my9nnr
7800X3D - PBO +200, CO -30 all cores, 4.90GHz all core, 5.05GHz single core, Cinebench 23: 18401 multi, 1779 single
Khaleesi: Ryzen 5 5600X3D (+200, -30) - ASRock B550M Pro4 - G. Skill Ripjaws V 16GB 3200CL16 - Asus Prime 9060XT 16GB - Samsung 980 1TB + Crucial MX500 1TB - Cudy AX3000 PCIe Wifi 6 - EVGA SuperNOVA 650 P2 - Thermalright Frozen Notte RGB 360 White V2 - NZXT H6 Flow RGB White - LG 34" 3440x1440
NAS/Plex/Game Server  Ryzen 9 5900XT 16c/32t - Gigabyte B550M AORUS Elite AX - TeamGroup T-Force Vulcan 64GB 3200CL16 - MSI 1050Ti 4GB - Crucial P3 Plus 500GB + TeamGroup MP44L 2TB (Game) + WD Red Plus 4TBx2 (Plex) - TP-Link AC1200 PCIe Wifi - EVGA SuperNOVA 650 P2 - Thermalright Peerless Assassin 120SE - ASUS Prime AP201 - Currently Hosting: Enshrouded x2, Hytale, Icarus, Windrose, Project Zomboid, Dune Awakening.
Sage: Ryzen 7 7800X3D (+200, -30) - Gigabyte B650 Gaming X V2 - ASRock Steel Legend 7900GRE - G. Skill Flare X5 32GB 6000CL32 - TeamGroup MP44L 2TB - Super Flower Leadex Platinum SE 1000w - NZXT H5 Elite
Emma: i9 9900K @5.2Ghz - Gigabyte Z370 AORUS Gaming 5 - MSI 6900XT Gaming X Trio - G. Skill Ripjaws V 32GB 3200CL16 - 750 EVO 512GB + 2x 860 EVO 1TB (RAID0) - Super Flower Combat FG 850w - Thermaltake Water 3.0 Ultimate 360 - Fractal Design Define R6 - TP-Link AC1900 PCIe Wifi
Extra parts: ASUS 6650XT - Gigabyte 1080Ti - Cooler Master Q300L - Gigabyte 450w PSU - Super Flower Leadex V Plat Pro 850w
OnePlus Ecosystem:
OnePlus 11 5G - 16GB RAM, 256GB NAND, Eternal Green. OnePlus Watch 2 - Radiant Steel, OnePlus Buds Pro 2 - Eternal Green
3D Printing:
Bambu Lab X1 Carbon, AMS, AMS2 Pro (thank you MicroCenter!)
Other Interesting Tech:
- 2021 Volvo S60 Recharge T8 PHEV Polestar Engineered - 415hp/495tq 2.0L 4cyl. turbocharged, supercharged and electrified.
That's why I bought it, one-time investment and such! My luck had other plans.
I haven't seen it with my eyes, my tech brother told it has a line after fixing.
If I see the condition is good, I guess, I'll have to test my luck again!
Thank you for your time. Much love.
Your choice
That's the thing! When my tech brother/middleman said it could cost $75+, I was like hell nah I will just buy another one. It's close to a month, I haven't been able to manage that kind of money. Even if I did buy another one, it would also bother me $260 worth of junk sitting there providing no value.
Having a rough time! I haven't seen the monitor condition with my eyes, my tech brother told it has a line after fixing.
Then I'll have to decide. Thank you for your time. Much love.
I forgot to mention one thing when it had initially a white screen, I could still see the details like names-pictures edges vaguely yet somehow clear but washed out full white. After giving it to someone to fix it had glitchy random spots and I could no longer see the details!
I haven't seen the monitor after it was repaired with my eyes, my tech brother told it has a line after fixing.
After seeing I gotta decide. Appreciate your help. Much love.
Actually, my tech brother/middleman did, he told me it could cost $75. I most definitely know I will have no warranty/guarantee. I immediately told him I got no interest to repair with such load of money and soon after there was Eid Ul Adha (Muslim's 2nd main holiday) so obviously no one worked. I contacted him some days after, but he didn't say anything about if it was repaired or something. I just told him to sell it off somehow. Then yesterday I called him again, and he said another party fixed it and the monitor is with them. They wants $60+!
Agree with you!
When I heard, it could cost $75+, I had the feeling I will just buy another one. It's close to a month, I haven't been able to manage that kind of money. Even if I did buy another one, it would also bother me $260 worth of junk sitting there providing no value.
Having a rough time! I haven't seen the monitor's condition with my eyes, my tech brother told it has a line after fixing.
After seeing then I'll have to decide.
Thank you for your time man. Much love.
1 hour ago, 37748585862723896 said:
Its all about the market price of your current monitor, as if you would sell that same working monitor now.
If he took 60 , is it a guarantee repair? Could you take money back if its totally dead?
I mean given the monitor's market price, $60 is not much. That's why they are asking so much ig!
Also, it's not a guaranteed repair, they will have no dirt on their hand, and I would have to risk my money.
I haven't seen the monitor's condition with my eyes, my tech brother told me it has a line after fixing.
You don't have to respond to each person with the same comment 🙂 We can see them  and get notified when a new comment is added.
So why don't you ask the guy to fix it 100%?  What did he say?
OnePlus Ecosystem:
3D Printing:
Sorry for bothering! Newbie here. I was just trying to reply personally and thank individually everyone for their time!
He said he's gonna update me tomorrow. Guess I'll have to wait to see actually what they have done.
Update!
Update!
OnePlus Ecosystem:
3D Printing:
