Will 450W PSU be enough for PowerColor Radeon™ RX 5700 XT?
5700XT consumes up to 220 watts. For very short periods of time (like milliseconds at a time), it peaks to 250 watts.
The 9400F can consume up to around 100-110 watts in heavy CPU benchmarks, while gaming maybe a bit less.
Everything else in your system (fans , mechanical hard drives if any, 12v rgb leds), add another 20-30 watts on 12v output.
So you need a power supply that can supply at LEAST 250w + 100w + 50w = 400w on 12v output. That's a minimum of 400w / 12v = 33.3A on 12v.
Look on the label and see if your power supply can supply this much power on 12v.
Keep in mind also that some models were only rated for continuous power at 30c ambient and if the temperature around the power supply goes over 30c you are supposed to derate the power supply by around 10-20%, making it a 360-400w power supply.
So will it work? Probably yes, because when you're gaming your CPU is not gonna be pegged at 100% so it's not gonna consume 100w. Same for the video card, it's not really gonna consume 220 watts all the time.
BUT, your psu will run at close to 100% when you're gaming and that's not good, considering it's a budget psu where they cheaped out on lots of things...
Ideally though, you should aim for at least a 600-650w power supply, which can provide at least 500 watts on 12v output.
