The rest of your system doesn't care about what type of VRAM your GPU has. The VRAM is only used by the GPU itself. GDDR6 is simply faster than GDDR5, that's all there is to it.
https://linustechtips.com/topic/1516908-does-gddr-matter/#findComment-16015312
One more question, Is 1660 same gen as 1050? (This time gens are meant as 20, 30 ect.
Edited by Krystof203PhoneAccc
https://linustechtips.com/topic/1516908-does-gddr-matter/#findComment-16015337
No, it's still the same Turing architecture found on the RTX 20-series cards. It's a lower end 20-series card that doesn't support RTX.
https://linustechtips.com/topic/1516908-does-gddr-matter/#findComment-16015339
So I will need to use DDU?
Nvidia's GeForce drivers tend to work across all GPUs they support, but I still DDU whenever I swap cards just to be safe.
https://linustechtips.com/topic/1516908-does-gddr-matter/#findComment-16015344
Speaking of drivers, when doing clean install should I run Win in safe mode or it is fine to let it install in normal mode?
Usually I run DDU in Safe Mode, but I know people who don't and they have no issues.
There's no point to installing drivers inside Safe Mode since Safe Mode won't actually load them. Safe Mode only loads the basic drivers built into Windows that allow your PC to function.
https://linustechtips.com/topic/1516908-does-gddr-matter/#findComment-16015351
Me using RTX in Control on a GTX 1660 (1080p,Max settings - RTX MEDIUM):
1080p,Max settings - RTX OFF:
A PC Enthusiast since 2011
AMD Ryzen 7 5700X@4.65GHz | GIGABYTE RTX 3080 GAMING OC | 4x 8GB Micron Rev.E (D9VPP) 3800MHz 16-19-14-21-58
https://linustechtips.com/topic/1516908-does-gddr-matter/#findComment-16015353
It's usually referred to as a 16-series card, as opposed to 10-series for the 1050 and 20-series for e.g. the 2060. It's basically a 20-series card, but lacks the RT cores that were added to the RTX 20xx cards (i.e. no official hardware support for ray tracing)
https://linustechtips.com/topic/1516908-does-gddr-matter/#findComment-16015382
I bet the same reflection could be had with RT off and if you swapped the images, people would be fooled. Devs don't need RT for excellent reflections 99% of the time.
CPU: Ryzen 5500 GPU: RX 6800 RAM: DDR4 3200MHZ 48GB (2x8+2x16 GB)  MOBO: MSI B450-A PRO Display: 4k120hz with freesync premium.
https://linustechtips.com/topic/1516908-does-gddr-matter/#findComment-16016675
16-series existed concurrently with 20-series. Both are the Turing architecture and both succeed the 10-series, but the 16-series lacks any RTX features such as RT and Tensor cores.
As for the memory subsystem, GDDR6 is simply the next version of GDDR from GDDR5/5X of the 10-series and as previously mentioned is entirely contained within the card so you don't need to worry about memory compatibility with your system like you would with traditional memory.
Zen 3 Daily Rig (2022 - Present): AMD Ryzen 9 5900X + Optimus Foundations AM4 | Nvidia RTX 3080 Ti FE + Alphacool Eisblock 3080 FE | G.Skill Trident Z Neo 32GB DDR4-3600 (@3733 c14) | ASUS Crosshair VIII Dark Hero | 2x Samsung 970 Evo Plus 2TB | Crucial MX500 1TB | Corsair RM1000x | Lian Li O11 Dynamic | LG 48" C1 | EK Quantum Kinetic TBE 200 w/ D5 | HWLabs GTX360 and GTS360 | Bitspower True Brass 14mm | Corsair 14mm White PMMA | ModMyMods Mod Water Clear | 9x BeQuiet Silent Wings 3 120mm PWM High Speed | Aquacomputer Highflow NEXT | Aquacomputer Octo
Test Bench:
CPUs: Intel Core 2 Duo E8400, Core i5-2400, Core i7-4790K, Core i9-10900K, Core i3-13100, Core i9-13900KS
Motherboards: ASUS Z97-Deluxe, EVGA Z490 Dark, EVGA Z790 Dark Kingpin
GPUs: GTX 275 (RIP), 2x GTX 560, GTX 570, 2x GTX 650 Ti Boost, GTX 980, Titan X (Maxwell), x2 HD 6850
Bench: Cooler Master Masterframe 700 (bench mode)
Cooling: Heatkiller IV Pro Pure Copper | Koolance GPU-210 | HWLabs L-Series 360 | XSPC EX360 | Aquacomputer D5 | Bitspower Water Tank Z-Multi 250 | Monsoon Free Center Compressions | Mayhems UltraClear | 9x Arctic P12 120mm PWM PST
https://linustechtips.com/topic/1516908-does-gddr-matter/#findComment-16016795
