Corrosion of demineralized water?
Solved by johnno23,
you will still require a form of algaecide and dont forget the water will heat up and cool down.......perfect breeding place for gunk that will block your micro fins on any cooling block.
also running 2 x 420 is fine on a single D5 but if you going so high end just get a second D5 as a redundancy as if you only have the one Pump in your system and should it ever fail you are facing downtime until you have a replacement and bled the system etc etc
I use 2 x D5 on a Dual Pump block and whilst the flow is improved a little nothing amazing but the security that if one fails my system does not care is golden
