Ok so , i was watching this show on one tv , i heard crackling noise, so i just thought the speakers had blown out , but then I watched the same episode on a different tv and i heard the same crackling sound , which leads me to believe its not the speakers, what should i do?
https://linustechtips.com/topic/1516437-crackling-sound/
https://linustechtips.com/topic/1516437-crackling-sound/#findComment-16011749
Could it be the episode?
https://linustechtips.com/topic/1516437-crackling-sound/#findComment-16011753
Nothing. If it's in the video file, you just watch it and continue on your day.
https://linustechtips.com/topic/1516437-crackling-sound/#findComment-16011756
If you heard it on 2 separate devices then it's the show. Nothing you can do really.
Community Standards
"Beast Mode"
Dedicated Streaming Rig
https://linustechtips.com/topic/1516437-crackling-sound/#findComment-16011797
This is the third post that I have found. How many times did you make this?
https://linustechtips.com/topic/1516437-crackling-sound/#findComment-16011809
Hard to say without experiencing it...could be the show, could be the service (likely only if cable?), and I'm honestly not sure about this one...but could the building wiring be lacking proper gounding? [very hazy recollection of hearing about something like that a while back, but it could have been abnormal context].
Are they the same make/model TV?
did you try other parts of the show or other shows?
lots of details you're leaving us guessing on...
https://linustechtips.com/topic/1516437-crackling-sound/#findComment-16011811
