PS5 issues with WD SN850 1TB
Voy
Hey all,
I have PS5.
I had WD SN850 1TB in it for a while for extra storage. No issues.
I took that SSD out and used it in my PC for a while. No issues.
I put it back into PS5... it doesn't see it at all.
I put it back to PC, it is working fine.
Any idea why PS5 would stop seeing it?
Might be refusing to touch it now it's been formatted for PC. Try completely wiping it.
Gaming system: R7 7800X3D, Asus ROG Strix B650E-F Gaming Wifi, Thermalright Phantom Spirit 120 SE ARGB, Corsair Vengeance 2x 32GB 6000C30, RTX 4070, MSI MPG A850G, Fractal Design North, Samsung 990 Pro 2TB, Acer Predator XB241YU 24" 1440p 144Hz G-Sync + HP LP2475w 24" 1200p 60Hz wide gamut
Productivity system: i9-7980XE, Asus X299 TUF mark 2, Noctua D15, 64GB ram (mixed), RTX 3070, NZXT E850, GameMax Abyss, Samsung 980 Pro 2TB, random 1080p + 720p displays.
Yeah, I thought of that as well.
I deleted the volume in Disk Manager in Windows and left it like that, but still nothing.
That still leaves some partitioning data on the drive. If you're familiar with it, diskpart clean it. If you're not, be extremely careful as you can easily wipe another drive by mistake. I'm not sure what other options there are to do that.
Hmm.... that is a good idea. I will clean it in disk part and see how it goes.
@porina Did some more digging. Unfortunately, my SN850 is faulty. It is working in Windows but uses 2 out of 4 pcie lanes. Thanks for your help!
