So I decided I'll go with a brand new Sigma Atlantis I stashed in the attic a decade ago.  It's 100% aluminum, including all the drive cages.  A lot of it is extrude, which while a little bit rough is still excellent for passive cooling.  This was the primary motivation why I bought it, it was a huge chunk of aluminum for not a lot of money.
https://www.newegg.com/silver-sigma-atlantis-atx-mid-tower/p/N82E16811226004
I'm hoping that even though it doesn't have that much airflow that the aluminum will be good at passive heat dissipation.
This post has been ninja-edited while you weren't looking.
I'm a used parts bottom feeder.  Your loss is my gain.
I like people who tell good RGB jokes.
https://linustechtips.com/topic/1514082-case-from-a-decade-ago/
1 hour ago, Lurking said:
You probably could mod it to have the whole front being filtered air intake. Keep those bars.
Yeah, possible, 3x 5.25" bays fit a 120mm fan nicely.  I could either find a bay adapter like that or 3D print it.  The 3.5" bays would work well for USB ports and card readers, and I probably still want an optical drive.
https://linustechtips.com/topic/1514082-case-from-a-decade-ago/#findComment-15993879
The blue LED fan was previously removed by me when I sold my original model Cooler Master Cosmos (I kept the quality CM fans 😁).  I was over the bright LED lights by mid-2000s.
https://linustechtips.com/topic/1514082-case-from-a-decade-ago/#findComment-15993885
One of my mod ideas was to drill and install handles into the top.  The top is very thick aluminum extrude, the handles would be functional.
It's no secret I like handles on my computers.
https://linustechtips.com/topic/1514082-case-from-a-decade-ago/#findComment-15993891
7 minutes ago, Kaetemi said:
Imagine that aluminum with pure white LEDs though. 😮
Heh, yeah, I'd go blind though.  It would look pretty good.  I'm thinking of replacing the indicator LEDs with white, right now power is green and HDD blue.
https://linustechtips.com/topic/1514082-case-from-a-decade-ago/#findComment-15993903
https://www.amazon.ca/Cooling-Graphics-Heatsink-bracket-Desktop/dp/B074JG2YC9/ref=sr_1_7?crid=PRK8P4BBDFJD&keywords=5.25+fan&qid=1687204031&sprefix=5+25+fan%2Caps%2C192&sr=8-7
https://linustechtips.com/topic/1514082-case-from-a-decade-ago/#findComment-15994968
1 hour ago, thrasher_565 said:
That's a strange bracket.  I was thinking more like:
https://www.printables.com/model/68734-120mm-fan-bracket-for-pc-525-inch-bays
https://www.thingiverse.com/thing:2936935
And what I can do is measure up my exact case opening and draw one up in SolidWorks no problem.  That way it won't have gaps in my case.
https://linustechtips.com/topic/1514082-case-from-a-decade-ago/#findComment-15995099
I removed the lower 3.5" drive cage because it will interfere with the airflow.
https://linustechtips.com/topic/1514082-case-from-a-decade-ago/#findComment-15995103
Unless the heat generating components are directly touching the aluminum, the passive cooling will be next to no - existent.
Cool retro case though.
https://linustechtips.com/topic/1514082-case-from-a-decade-ago/#findComment-15995268
What I didn't mention is that I have 3 more of them...
If I ever have a rig where I don't want any external bays I just might do that.  Just take a dremel to the case front behind the grill and cut away all the material that blocks the airflow, then add some 3D-printed fan brackets.  Should fit 3 120 or 140mm fans.
https://linustechtips.com/topic/1514082-case-from-a-decade-ago/#findComment-15995272
11 minutes ago, Lightbop said:
How I miss my CM stacker 😭😭
I remember when they had the Nvidia Stacker.  I scoffed at it at the time, but a couple years later regretted not getting one.  I bet they're semi-collectible now.
https://linustechtips.com/topic/1514082-case-from-a-decade-ago/#findComment-15997501
