Dual Monitor Noob Question
Sparky862
While I am waiting on my 1440p Monitor to arrive, I came to the conclusion that I want to use my 1080p Monitor for research.
So I want to game on my 1440p, and let's say I play a game that requires collecting 300 collectables, I want to open a Map found on Google on my 1080p Monitor while still playing ony 1440p. So while I game I can use my 2nd monitor without Alt Tabbing in and out of my game.
Question is do I just connect my two monitors up and I am good to go?? Or how do I do the settings so I can game on my 1440p while my 1080p is just my information monitor?
You are just good to go, if your games start appearing on the wrong screen, you can go into display settings and choose which is your "main display" all your games will appear on the screen labelled as "main display"
You can change the order of monitors from Windows or your video card's settings, so that your 1440p monitor will be reported as the primary monitor to games, and games will automatically start on the main monitor.
It's also worth adjusting the layout of the monitors while in display settings so that the layout in windows matches the layout on your desk, otherwise your mouse might not behave as expected when moving across from one screen to the other. You can just drag the monitor icons around to match how they are physically positioned in relation to each other.
For example: if they're both the same resolution, and next to each other, you can arrange them like this:
Lastly you should set your games as Windows borderless instead of full screen for easier navigation in and out your games to another monitor.
Also due to your both monitor is in different resolution, the transition of in between monitor may not that smooth and instead you will seen mouse cursor jumping and also big and small look in between, this is unavoidable unless both monitor is same resolution and same screen size.
PC: AMD Ryzen 9 5900X, Gigabyte GeForce RTX 4090 OC 24G, X570 AORUS Elite WIFI Motherboard, HyperX FURY 32GB DDR4-3200 RGB RAM, Creative Sound Blaster AE-9 Sound Card, Samsung 970 Evo Plus M.2 SATA 500GB, ADATA XPG SX8200 Pro M.2 SATA 2TB, Asus HyperX Fury RGB SSD 960GB, Seagate Barracuda 7200RPM 3.5 HDD 2TB, Cooler Master MASTERLIQUID ML240R ARGB, Cooler Master MASTERFAN MF120R ARGB, Cooler Master ELV8 Graphics Card Holder ARGB, Asus ROG Strix 1000G PSU, Lian Li LANCOOL II MESH RGB Case, Windows 11 Pro (22H2).
Laptop: Asus Vivobook "A Bathing Ape" - ASUS Vivobook S 15 OLED BAPE Edition: Intel i9-13900H, 16 GB RAM, 15.6" 2.8K 120hz OLED | Apple MacBook Pro 14" 2023: M2 Pro, 16 GB RAM, NVMe 512 GB | Asus VivoBook 15 OLED: Intel® Core™ i3-1125G4, Intel UHD, 8 GB RAM, Micron NVMe 512 GB | Illegear Z5 SKYLAKE: Intel Core i7-6700HQ, Nvidia Geforce GTX 970M, 16 GB RAM, ADATA SU800 M.2 SATA 512GB.
Monitor: Samsung Odyssey OLED G9 49" 5120x1440 240hz QD-OLED HDR, LG OLED Flex 42LX3QPSA 41.5" 3840x2160 bendable 120hz WOLED, AOC 24G2SP 24" 1920x1080 165hz SDR, LG UltraGear Gaming Monitor 34" 34GN850 3440x1440 144hz (160hz OC) NanoIPS HDR, LG Ultrawide Gaming Monitor 34" 34UC79G 2560x1080 144hz IPS SDR, LG 24MK600 24" 1920x1080 75hz Freesync IPS SDR, BenQ EW2440ZH 24" 1920x1080 75hz VA SDR.
Input Device: Asus ROG Azoth Wireless Mechanical KeyboardAsus ROG Chakram X Origin Wireless MouseLogitech G913 Lightspeed Wireless RGB Mechanical Gaming Keyboard, Logitech G502X Wireless Mouse, Logitech G903 Lightspeed HERO Wireless Gaming Mouse, Logitech Pro X, Logitech MX Keys, Logitech MX Master 3, XBOX Wireless Controller Covert Forces Edition, Corsair K70 RAPIDFIRE Mechanical Gaming Keyboard, Corsair Dark Core RGB Pro SE Wireless Gaming Mouse, Logitech MK850 Wireless Keyboard & Mouse Combos.
Entertainment: LG 55" C9 OLED HDR Smart UHD TV with AI ThinQ®, 65" Samsung AU7000 4K UHD Smart TV, SONOS Beam (Gen 2) Dolby Atmos Soundbar, SONOS Sub Mini, SONOS Era 100 x2, SONOS Era 300 Dolby Atmos, Logitech G560 2.1 USB & Bluetooth Speaker, Logitech Z625 2.1 THX Speaker, Edifier M1370BT 2.1 Bluetooth Speaker, LG SK9Y 5.1.2 channel Dolby Atmos, Hi-Res Audio SoundBar, Sony MDR-Z1R, Bang & Olufsen Beoplay EX, Sony WF-1000XM5, Sony WH-1000XM5, Sony WH-1000XM4, Apple AirPods Pro, Samsung Galaxy Buds2, Nvidia Shield TV Pro (2019 edition), Apple TV 4K (2017 & 2021 Edition), Chromecast with Google TV, Sony UBP-X700 UltraHD Blu-ray, Panasonic DMP-UB400 UltraHD Blu-ray.
Mobile & Smart Watch: Apple iPhone 15 Pro Max (Natural Titanium), Apple Watch Series 8 Stainless Steel with Milanese Loop (Graphite).
Others Gadgets: Asus SBW-06D2X-U Blu-ray RW Drive, 70 TB Ext. HDD, j5create JVCU100 USB HD Webcam with 360° rotation, ZTE UONU F620, Maxis Fibre WiFi 6 Router, Fantech MPR800 Soft Cloth RGB Gaming Mousepad, Fantech Headset Headphone Stand AC3001S RGB Lighting Base Tower, Infiniteracer RGB Gaming Chair
But what keeps my cursor in the game and it not running over to the other Monitor while gaming?
Does it work same as Alt Tabbing? Also is Windows Mode not bad for gaming performance where you always want Fullscreen?
This is not an issue in most games. In games where the mouse is essential for movement (such as shooters) you have to alt+tab regardless to move the mouse to another screen. In games like WoW where the cursor is important, but doesn't work as it does in a shooter, just don't move it off the edge of the screen.
If you don't want running over, then just choose Full Screen.
Full Screen and Windows borderless is similar performance most of it. But still Full screen is better for all.
Some games will lock the mouse to the screen with the game until you press ESC to get into the menu, or until the game is alt-tabbed
Very few games actually have such issues (mouse going outside game area to 2nd monitor) for example the only one I can think of now is the old Bloodrayne game.
