Can I create a wireless antenna for a broken laptop by soldering wire to the snap heads?
Solved by samygiy,
You can, but I wouldn't recommend it as an actual fix, should be fine just for learning though. What you're going to make is a monopole antenna, this will connect to the centre pin of the snap connector (don't short it to the edge!). To size it, look at the wavelength of a wifi signal: 2.4GHz -> 125mm. For good performance make it 1/4 of the full wavelength: 31.4mm. Take a piece of wire, cut it to this length and solder the end to that centre pin. This should "work", however the performance will probably be terrible, as it won't be impedance matched.
Make sure the wire stays straight for "better" performance.
