Help with undervolting
Solved by unclewebb,
You need to undervolt the core and the cache. Start more conservatively. Do some testing at -100 mV or -75 mV for both. Try running the TS Bench 960M test. This is a good first test to check for stability. If it reports any errors, the CPU needs more voltage.
Featured Topics
Emmanuel Katto ·
Posted in Peripherals0 -
1
2
Rusty Proto ·
4
WildOne ·
Posted in New Builds and Planning1 -
solarbear ·
Posted in Troubleshooting1 -
4
2
2
play_circle_filled
Latest From ShortCircuit:
Lian-Li, do this on all of your cases! - Lian-Li O11D x Lamborghini
