Running 4070 ti on a 450 watt Corsair PSU
Solved by Crunchy Dragon,
32 minutes ago, Parvesh Khatri said:The problem is that I only have a 450-watt PSU. Some say a 4070 ti need more than 650-watt PSU. But its power draw is less than 300 watts. The i5 8400 eats 65-watt max I think.
So, should I run the 4070 ti with the 450-watt PSU?
You need to account for everything else in your PC that draws power. Motherboard, RAM, SSDs, hard drives, LEDs, fans, USB devices, all of it. If anything is overclocked at all, that will draw even more power.
With that said, you can install a 4070Ti into that system and it will work for a little bit, but you should absolutely expect your PC to shut down if you throw any half-serious load on that GPU.
