Hp battery upgrade
2 hours ago, Mal707 said:The model of the laptop is a 16-a0032dx
Unfortunately, it looks like the original 52Wh battery or a direct replacement is your only internal battery option. There's only so much room for a battery inside a thin and light laptop, especially one that's been engineered to an "entry level" price point. (Build quality and battery capacity are usually the first compromises manufacturers make.)
Installing a new replacement battery will get you back to about factory performance, but you won't be able to run FurMark for hours.
I haven't been able to find a definitive answer as to whether your laptop supports USB power delivery, and most car DC outlets are designed to only support 120 watts (12 volts at 10 amps), so a Jackery might actually be your only external battery option. (I was joking earlier...)
There are gains to be made on the software side, though. Lowering your graphic fidelity settings and capping your FPS at 60 should make it so your laptop doesn't work as hard. Even turning the screen brightness down can help. Limit your background tasks, and maybe get a second stick of RAM if you haven't already.
