UEFI Firmware Settings missing.
Go to solution Solved by Volbet,
Hi again Volbet! Yea i keep trying and it just takes me to Windows.
Hi again.
I think i have found I a solution. The Asus Fast Boot feature is probably turned on, so it doesn't ´boot´ the BIOS as it normally would.
Download AI Suite form the Asus Website and in that program, there should be something called "Asus Boot Settings" and there you just check ´Direct BIOS´
Edit: Found a link to the program itself: http://dlcdnet.asus.com/pub/ASUS/misc/utils/ASUS_Boot_Setting_V10010.zip
Perhaps if its easier..Could i just uninstall windows?
That wouldn't really be a practical solution, and I would reserve that as a last resort
Hello all..
I just recently installed windows 8.1 onto a brand new pc build..However I am trying to get back into the uefi bios to make some tweaks but everytime i go to my settings where the "Uefi Firmware Settings" should be....it is simply missing.
Any ideas?
https://linustechtips.com/topic/150783-uefi-firmware-settings-missing/
Motherboard?
Maybe fastboot is enabled...
Try with an PS/2 keyboard or clear CMOS
Desktop: Intel i9-10850K (R9 3900X died 😢 )| MSI Z490 Tomahawk | RTX 2080 (borrowed from work) - MSI GTX 1080 | 64GB 3600MHz CL16 memory | Corsair H100i (NF-F12 fans) | Samsung 970 EVO 512GB | Intel 665p 2TB | Samsung 830 256GB| 3TB HDD | Corsair 450D | Corsair RM550x | MG279Q
Laptop: Surface Pro 7 (i5, 16GB RAM, 256GB SSD)
Console: PlayStation 4 Pro
Lol what does that mean?
PS/2 are the green and violet connectors used on old keyboard and mice.
CMOS is where you're BIOS settings are stored, clearing it will reset all settings to default.
How to clear your CMOS depends on your motherboard. Try to look it up in your motherboards manual.
Hi again.
Nova doctrina terribilis sit perdere
Audio format guides: Vinyl records | Cassette tapes
Hi again.
Ok thanks will try that out...I wouldn't mind uninstalling since I have done nothing on the computer yet.
Hi again.
You are a god.
