High Hot Spot Temps on Vega 56
Sounds like it's gonna need to be disassembled.
Good news with that is that it's not nearly as hard as it sounds.
I would consider myself still a rookie (4 disassembly and reassembles done) and as long as you have the right size screw driver, a lint-free cloth, and some high % IPA and some thermal paste, it's just a matter of taking your time.
I also used a few q-tips for spot cleaning small spots but it sounds like you should be fine without.
The most intimidating part for me was the keeping track of where everything went, and for that I got a cookie sheet and some scotch tape to keep things in place and lay out where it all went.
Total time on first one was about 40 min (had a stuck screw that took some pursuasion and that ate up about 5 min all on its own)
