Quiet 70 MM fan
Moesby_DK
Hi, does anyone have a good suggestion for a quiet 70mm fan for a NAS, the one sitting in it now sounds like a plane about to take off 馃檪
The dimensions are 70mm*70mm*25mm with a 4 wire connection
i cant find any options. posably a 60mm fan will fit? dont think an 80mm fan will thow.
https://www.amazon.ca/Noctua-60x25mm-Premium-NF-A6x25-PWM/dp/B00VXTANZ4/ref=sr_1_3?keywords=60mm+pwm+fan&qid=1683469995&s=pc&sr=1-3
Corsair Lian Li Bykski Barrow thermaltake nzxt aquacomputer 5v argb pin out guide + argb info
5v device to 12v mb header
Odds and Sods Argb Rgb Links
Not the answer I was hoping for, but maybe if I 3d print an adaptor plate it will fit聽聽
it won't be the best but there's this聽BOFLAX 12V DC 32 70mm 4-Pin Computer Case CFM PWM CPU PC Fan Blue & Black : Amazon.co.uk: Computers & Accessories聽or that noctua聽
Message me on discord (bread8669) for more help聽
Current parts list:聽
CPU: R5 5600 CPU Cooler: Stock
Mobo: Asrock B550M-ITX/ac
RAM: Vengeance LPX 2x8GB 3200mhz Cl16
SSD: P5 Plus 500GB Secondary SSD: Kingston A400 960GB
GPU: MSI RTX 3060 Gaming X
Fans: 1x Noctua NF-P12 Redux, 1x Arctic P12, 1x Corsair LL120
PSU: NZXT SP-650M SFX-L PSU from H1
Monitor: Samsung WQHD 34 inch and 43 inch TV
Mouse: Logitech G203
Keyboard: Rii membrane keyboard
Damn this space can fit a 4090 (just kidding)
Thanks for the link @filpo, but I think that I will take the 60mm, that gives me a good reason to buy a 3d printer to make my own adaptor plate聽馃ぃ
