Replacing Thermal Pads and Thermal Paste On GTX1070TI GIGABYTE OC
Solved by SorryBella,
1 hour ago, Meczox_ said:So I can just try measure the old pads length with a rule or something n cut it according to that right?
yeah, the main concern here is thickness. Either stick to stock height or check out with other owner of the same card model on what thickness works either in parity or even better than factory.
