Power Supply surge detected?
Tola
So I was playing CS:GO and then my computer shut down and turned on again with a flickering screen saying "Power supply Surge detected". After this I turned it off, unplugged the PSU and then I noticed a bad smell in my room. The PSU is connected to a surge protector. What should I do?
PLEASE USE PCPARTPICKER.  My rig: http://pcpartpicker.com/p/ZBmWjX
Try a different power supply and then try a different power supply without the surge protector and see if the smell comes back.
Twitter | Steam |
I only have 1 power supply.
Time to get a new PSU...
unless you want to risk frying your components
Happened to my of rig.... But no surge, it smelled really bad like a burning smell, got a new psu, fixed everything
I Love Playing CS:GO!
Current
AMD Athlon X4 760K | MSI A78M-E45 | Sapphire R7 265 | Cougar Solution | Cooler Master Hyper T4 | ADATA XPg V1.0 1600Mhz 8GB | Fractal Design 650W
