Wierd sound issue
Go to solution Solved by creatip123,
Try fiddling with the onboard audio's application (not the default windows sound application). Most probably it's realtek (dunno for sure though). Go to control panel, and find the icon that has 'realtek audio' or something like that. Open, and fiddle with it.
If all else fail, try reboot, go to bios, disable onboard audio. Unplug front jack (if it's plugged), and boot normally. Then restart again, go to bios again, and re-enable the onboard audio. This is a kind of 'soft reset'
Okay this is wierd for me, but maybe im just to dumb to realize a simple solution, but i wanted to use my earbuds with my pc, so i plugged them into the from of the pc, and unplugged my headset from the back, nothing worked, so i restarted my pc, and re installed the driver, now the problem is that it only has sound going through the front, and I cant figure out how to switch it to go from the rear, my mobo is a sniper 5, and if any impotance case is the 750d.
Mouse: Razer Death Adder 2013 Keybaord: Razer Black Widow Ultimate 2013
https://linustechtips.com/topic/150335-wierd-sound-issue/
you switch sound output in the OS, in the sound options, its not always automatic
where in the os though, I have been in sound options looking at different options and cant figure out where the option is to switch?
https://linustechtips.com/topic/150335-wierd-sound-issue/#findComment-2008872
then down to your right there is a speaker icon, right click and click playback devices and you will see all your audio outputs, from there you pick the one you want and set it as default, if you have to you might need to right click the other and disable it to force your computer to switch as it can bug.
Proud Member of the Glorious PC Master Race
https://linustechtips.com/topic/150335-wierd-sound-issue/#findComment-2008890
Thats the problem, the only one that comes up is speakers, which is the same what use to come up for the rear, and then there is spidif out, wich is the port on the back for a mic/audio combo jack, but i need the audio and mic seprate one. Sorry, imean that the optical jack, so i dont use it.
https://linustechtips.com/topic/150335-wierd-sound-issue/#findComment-2008905
you haven't accidentally or maybe its default, if you right click the speakers and make sure everything is on "show" such as disabled and disconnected
yeah its on show, got my three pa 248q disabled, spidif, and speakers that is all that there.
https://linustechtips.com/topic/150335-wierd-sound-issue/#findComment-2008919
i dont have more, im guessing there is something else wrong, because i got the back spdif and speakers(+ my amp/dac and usb headset)
okay, well time to call gigabyte then, sorry, to bother thanks for trying.
https://linustechtips.com/topic/150335-wierd-sound-issue/#findComment-2008943
this was the day i was going to ath-m50x headphones too, so now i have this issue, im gonna hold of, haha
https://linustechtips.com/topic/150335-wierd-sound-issue/#findComment-2008955
https://linustechtips.com/topic/150335-wierd-sound-issue/#findComment-2009129
this worked, should have thought of this, but thanks, its working again, thank you very much.
https://linustechtips.com/topic/150335-wierd-sound-issue/#findComment-2009197
Which one? The fiddling with the application, or the soft reset one?
https://linustechtips.com/topic/150335-wierd-sound-issue/#findComment-2009257
