Building my first pc ever, don't really know how to put it together, tried doing it but it does not look right and doesn't work. Seeking for some help from people here
Here is the part that I have
Processor: I9-13900k
Ram: 4 32gb Corsair vengeance cl40 6000mhz
Storage: Western digital SN850X
Motherboard: Asus Rog Maximus extreme
Graphics card: 4090 Founders Edition
PSU: Corsair Ax1600i
Cooler: NZXT Kraken Z73 RGB
Case: Lian li o11 dynamic evo
Sorry if I didn't mention I currently have all the parts right now I need help on how to put it together, because I'm a complete noob so yeah☹️
https://linustechtips.com/topic/1503173-need-help/
Ram: Corsair vengeance cl40 6000mhz
Never built a pc before so I really need help
Godzilla build 🙂
99% of people wanting a 13900K should get a 13700K, it's the same with a very slightly slower clock speed and 8 ecores less, but those are only useful for productivity. Then the 13700K is way easier to cool and eats way less power
You could also get a way cheaper board, any $400+ Z790 has all you need
But get faster RAM, 6400+/CL30
https://linustechtips.com/topic/1503173-need-help/#findComment-15910610
get an arctic liquid freezer ii 360 instead for cooler
maybe get a 7800x3d for max gaming on an x670 msi board. And then get a 980 pro 2tb instead
Message me on discord (bread8669) for more help
Quote me if you want me to get notified
Current parts listPCPartPicker Part List
CPU: AMD Ryzen 5 7600 3.8 GHz 6-Core Processor  (Purchased For £175.00)
CPU Cooler: Thermalright Phantom Spirit 120 SE ARGB 66.17 CFM CPU Cooler  (Purchased For £0.00)
Motherboard: MSI PRO B650M-A WIFI Micro ATX AM5 Motherboard  (Purchased For £144.99)
Memory: Corsair Vengeance 32 GB (2 x 16 GB) DDR5-6000 CL30 Memory  (Purchased For £89.99)
Storage: Crucial P5 Plus 500 GB M.2-2280 PCIe 4.0 X4 NVME Solid State Drive  (Purchased For £0.00)
Storage: Kingston A400 960 GB 2.5" Solid State Drive  (Purchased For £0.00)
Video Card: Gigabyte GAMING OC Radeon RX 7800 XT 16 GB Video Card  (Purchased For £448.99)
Case: Lian Li LANCOOL 205M MESH MicroATX Mini Tower Case  (Purchased For £82.98)
Power Supply: MSI MAG A850GL PCIE5 850 W 80+ Gold Certified Fully Modular ATX Power Supply  (Purchased For £99.00)
Total: £1040.95
Damn this space can fit a 5090 (just kidding, it needs more)
https://linustechtips.com/topic/1503173-need-help/#findComment-15910695
I wouldn't want to learn how to build a PC on such expensive hardware....
How about get a old gaming computer from craigslist as practice? There are things like 10, 20 years old and they cost nothing. There you can learn how to take things apart and how to assemble. That should give you some confidence.
How to properly spec a PC is another story....
https://linustechtips.com/topic/1503173-need-help/#findComment-15911154
With how expensive these parts are and that you have already attempted to build it and power it on, I would recommend taking it to a shop. Having a professional build this for you is your best bet, especially if you may have messed up or damaged something in your initial attempt. If you don't want to risk your parts... please, have a professional build it.
Honestly, probably shouldn't have used these parts for your first build attempt anyway.
Main Desktop: CPU - i9-14900k | Mobo - Gigabyte Z790 Aorus Elite AX | GPU - PNY Gaming OC RTX 5080 16GB RAM - Corsair Vengeance Pro RGB 64GB 6400mhz | AIO - Arctic Liquid Freezer III 360mm | PSU - Corsair RM1000X | Case - Hyte Y40 - White | Storage - Samsung 980 Pro 1TB Nvme /  Sabrent Rocket 4 Plus 4TB Nvme / Samsung 970 EVO Plus 2TB Nvme / Samsung 870 EVO 4TB SSD / Samsung 870 QVO 2TB SSD/ Samsung 860 EVO 500GB SSD|
Phone: Samsung Galaxy S26 Ultra - Black 256GB |
https://linustechtips.com/topic/1503173-need-help/#findComment-15911313
Could you elaborate on how it "doesn't look right and doesn't work"? Do the fans spin? Any lights come on? Perhaps RGB lights up? Any beeping sounds of sorts? More information would help us here.
The alternative is you could take it to a shop and see if they could help, cause the last thing you want is to blow up a many thousand dollar PC.
Keep in mind that I am sometimes wrong, so please correct me if you believe this is the case!
"The Nvidia Geforce RTX 3050 is brutally underrated"
https://linustechtips.com/topic/1503173-need-help/#findComment-15911370
The fan spins, RGB turns on, I can also get it on BIOS just that after attempting to download the operating system it would never connect
https://linustechtips.com/topic/1503173-need-help/#findComment-15911499
A PC doesn't download the OS itself, you need to install it.
Take a spare thumb drive without data and follow the guide
https://support.microsoft.com/en-us/windows/create-installation-media-for-windows-99a58364-8c02-206f-aa6f-40c3b507420d
Then you can boot from the thumb drive and follow the installer. The installer should be intuitive enough nowadays.
Then it will ask you to activate or buy a license. Try login with your Microsoft online account because sometimes you already have a license linked to your account.
If you need to buy a license, there are many legit sellers. I don't think you should go any shady paths such as volume license etc.
If you want to use Linux the process is pretty much same, minus the license part. But if you use Linux, you probably won't be asking here 😄
https://linustechtips.com/topic/1503173-need-help/#findComment-15911518
I did try to install OS with a key, but after downloading and restarting it just never shows up, even if i boot from the drive i downloaded it into
https://linustechtips.com/topic/1503173-need-help/#findComment-15911620
I see, so your problem is can't unable to boot from USB.
Could you elaborate how did you manually boot from the drive. By the boot order override menu?
Could you show which entries are listed in that menu. Also a screenshot of the boot setting in BIOS
If the USB key is plugged into an USB port in front try the back ones.
https://linustechtips.com/topic/1503173-need-help/#findComment-15911622
If the USB key is plugged into an USB drive in front try the back ones.
https://linustechtips.com/topic/1503173-need-help/#findComment-15911633
It is plugged in from the back, so I was wondering
https://linustechtips.com/topic/1503173-need-help/#findComment-15911637
11 minutes ago, ryd994 said:
The option looks fine. There seems like a windows installed on your 4TB WD drive too.
Is your problem unable to boot into the installer or unable to boot into the windows after install ?
Is there any error message?
No error message that I'm looking at, it's just black screen and unable to find signal
https://linustechtips.com/topic/1503173-need-help/#findComment-15911645
no do not download the os to a drive. download it to a usb thumb stick
https://linustechtips.com/topic/1503173-need-help/#findComment-15914504
I downloaded it from this thing, just tried to boot it but once I choose to boot the os that is already downloaded the screen just turn black and monitor is not getting any signal
https://linustechtips.com/topic/1503173-need-help/#findComment-15915052
hi look you have 2 many threads about the same issue. i get it you spend all this money on a pc and dident know how to build it and possibly broke it. i would try and go to a repair shop as each thread seems to have different information and be at different stages. if you want me to help you more pls reply to this with all the info you can give specs what is not working how what is working (fans,troubleshooting lights bios ect)
https://linustechtips.com/topic/1503173-need-help/#findComment-15915334
Mobo: Asus rog maximus z790 extreme
graphic card: 4090 founder
processor: i9 13900k
ram: corsair vengeance cl40 6000mhz
storage: Western digital sn850x black
cooler: nzxt kraken z73 rgb
monitor: alienware aw3418dw
I been planning on to bring it to someone for repair.
The fans work, spins, rgb turns on, able to enter bios, but not able Boot from the drive, not signal showing on monitor, entered the OS once but couldn't find wifi . The Mobo do have an external wifi adapter and I have it connect to the motherboard.
https://linustechtips.com/topic/1503173-need-help/#findComment-15918002
