So I'm building a PC with the help of the linus tech tips forum So so far I choose a Intel core i7 4770k,16GB of ram an atx motherboard,ASUS DCUII gtx 780,samsung 840 pro 256gb for a boot drive,WD black 1TB for a storage drive and a corsair H110 for the cpu cooler.
The pc is going to be overclocked so i need a case with good air flow for about 120$-150$
Please help!!!
https://linustechtips.com/topic/150283-what-pc-case-should-i-use/
If you can push the $10 go for the 750D from corsair!
EDIT: Plus it will give you plenty of room for upgrades in future.
Case: Carbide 300R
CPU: i5 4690K @ 3.90GHz
RAM: 8GB DDR3
Mobo: MSI Z97-G45 Gaming
GPU: R9 290 Tri-X
PSU: EVGA SUPERNOVA NEX650G
Storage: 4TB NAS
Drive 1: Seagate 1TB 7200RPM
Drive 2: WD 500gb 7200RPM
___________________________
Keyboard: Vengeance K50
Headset: Vengeance 1500 V2
Mouse: R.A.T 5
Monitor: LG 24EN33
Why don't you post a thread in build planning, and we will help you out with the Hole build at once instead of one Part at a time my friend
 Crust : Intel Core i5 4690K @ 4.4Ghz 1.45v  |  MotherboardMSI Z97 MPower  |  Fruity FillingMSI GTX 960 Armor 2Way-SLI |  CoolingNoctua NH-D15  |  RAM : 16GB Corsair Vengeance 1600Mhz | Storage : 2xSamsung 840 EVO 500GB SSDs Raid-0  |  Power Supply : Seasonic X-Series 1250W 80+Gold  |  Monitor : Dell U2713HM 27" 60Hz 1440p  |
Or the 450D because its in the price range and has better airflow because of the grill
|| MAELSTROM ||
|| i5 3570K W/ CM 212x @ 4GHz || r9 290 Windforce || Corsair Obsidian 450D || 2tb HDD + 120gb 840 evo SSD || 2x4gb Hyperx Fury Blue
I didnt realize that I can do that because I'm farily new to this forum.
sure you can mate, just go to Main/new builds and planning/, and post a thread there, just indicate your budget, use and location, and if you need a mouse and monitor...etc, post it and we will hit with several full builds and discuss them and you will get out of hear with best config you can get
