What kind of HDMI Cable ?
Poinkachu
Heya guys,
I need to run a male to female hdmi cable to a location around 15 meters from the TV , will any HDMI cable do, or do I need some sort of special cable / special apparatus in addition to the cable ?
Refresh before you reply
25 minutes ago, Poinkachu said:
Heya guys,
15 meters is around 49 feet, and according to this here google search,
There's this here google turned up https://www.popularmechanics.com/home/how-to/a6751/how-to-extend-your-hdmi-cables/
theres a problem with that. resolution plays a HUGE part
1080p up to 50' copper depending on cable quality
2k htz? can also use up to 50' copper depending on quality
4k? 4k 60htz i believe is 10' copper after that you need optical or other means of boosting the signal
4k 120htz is 6' certified copper after that optical. theres been a couple copper hdmi that have done 10'
Well, currently the one asking me for help uses 2k at most, but if it's feasible and not too expensive I may as well give him the option to future proof it in case he wants to go 4k.
I dunno what to get to achieve it though.
well if you want to go hdmi 2.1 just make sure its certified hdmi 2.1 optical. and these can get pretty pricey. but have been coming down in price since release
but heres a couple examples
uncertified
https://www.amazon.com/Optic-48Gbps-Dynamic-Vision-HDCP2-2/dp/B07ZF88GDM?th=1
certified
https://www.amazon.com/Certified-Fiber-Optical-Cable-phoossno/dp/B09LZ2J9KS?th=1
but if you look around you can find decent priced ones. but prices are because its still new and optical and length
