Is it normal for a NVME SSD to be running hot while mostly idle?
amsga
Go to solution Solved by GuiltySpark_,
1 hour ago, amsga said:
Now I'm wondering if I should go find a proper heatsink or find a better thermal pad if the ASUS cover was meant to be a heat sink.
Overthinking it. Years ago I ran a 970 Evo on the backside of an ITX motherboard with zero airflow, it was fine. If it was a high performance Gen4 drive things might be different.
Don't look at the temps and just use the PC.
Hi All,
I have a Samsung 970 Evo 1 TB NVME SSD that occasinally will run at low 60s degrees celsius even though I don't think it's doing anything.
This reading is from CrystalDiskInfo.
Post boot temperature may be around high 30s to low 40s due to my tropical climate, I think.
I am running it on a ASUS ROG STRIX X570-F, if that is part of any consideration.
Thank you.
21 minutes ago, Shimejii said:
Yes its pretty normal. Most run between 50-65c as their operating temps, if you dont have any heatsink on them especially yeah.
I don't think there's a heat sink per se, but supposedly there is some form of cover for the SSD?
21 minutes ago, Ottoman420 said:
I would say thats warm,
How is airflow in the case?
https://www.samsung.com/uk/memory-storage/nvme-ssd/970-evo-plus-nvme-m-2-ssd-1tb-mz-v7s1t0bw/
specs say up to 70c
I wouldn't say it is ideal, but my HDDs runs around 40 degrees celsius.
There's supposed to be some sort of intake fan at the shroud area.
The cover is just an heat trap. IIRC, some parts of m.2 like the heat as normal operating temps. While other components like it cold. (think it was controller vs actual storage chips)
For many reasons, you can't compare SSD's to HDD's. And this is one of them.
Yes, the NAND when it’s working like to be hot.
when it’s power off, NAND like to be cold.
And the controler like to be cold.
CPU : Intel 14gen i7-14700K
COOLER :  Thermalright Peerless Assassin 120 White + thermaltake toughfan 12 white + Thermal Grizzly - CPU Contact Frame Intel 13./14. +  Coollaboratory Liquid Ultra
GPU : MSI RTX 2070 Armor @GPU 2050MHz Mem 8200MHz -> USB C 10Gb/s cable 2m -> Unitek 4x USB HUB 10 Gb/s (Y-HB08003)
MOBO : MSI MEG Z690 UNIFY
RAM :  Corsair VENGEANCE DDR5 RAM 64 GB (2 x 32 GB) 6400 MHz CL32 (CMK64GX5M2B6400C32)
SSD : Intel Optane 905P 960GB U.2 (OS) + 2 x WD SN850X 4TB + 2 x PNY CS3140 2TB + ASM2824 PCIe switch -> 4 x Plextor M8PeG 1TB + flexiDOCK MB014SP-B -> Crucial MX500 2TB + GoodRam Iridium PRO 960GB + Samsung 850 Pro 512GB
HDD : WD White 18TB WD180EDFZ + SATA port multiplier adp6st0-j05 (JMB575) ->  WD Gold 8TB WD8002FRYZ + WD Gold 4TB WD4002FYYZ + WD Red PRO 4TB WD4001FFSX + WD Green 2TB WD20EARS
EXTERNAL
HDD/SSD :
XT-XINTE LM906 (JMS583) -> Plextor M8PeG 1TB + WD My Passport slim 1TB + LaCie Porsche Design Mobile Drive 1TB USB-C + Zalman ZM-VE350 -> Goodram IRDM PRO 240GB
PSU :  Super Flower leadex platinum 750 W biały -> Bitfenix alchemy extensions białe/białe + AsiaHorse 16AWG White
UPS :  CyberPower CP1500EPFCLCD -> Brennenstuhl primera-line 8 -> Brennenstuhl primera-line 10
LCD :  LG 32UD59-B + LG flatron IPS236 -> Silverstone SST-ARM11BC
CASE :  Fractal R5 Biały + Lian Li BZ-H06A srebrny + 6 x Thermaltake toughfan 14 white + Thermalright TL-B8W
SPEAKERS :  Aune S6 Pro -> Topping PA3-B -> Polk S20e black -> Monoprice stand 16250
HEADPHONES :  TOSLINK 2m -> Aune S6 Pro -> 2 x Monoprice Premier 1.8m 16AWG 3-pin XLR -> Monoprice Monolith THX AAA 887 -> 4-pin XLR na 2 x 3.5mm 16 cores OCC 2m Cable -> HiFiMAN Edition XS -> sheepskin pads + 4-pin XLR na 2 x 2.5mm ABLET silver 2m  Cable -> Monoprice Monolith M1060 + Brainwavz HM100 -> Brainwavz sheepskin oval pads + Wooden double Ɪ Stand + Audio-Technica ATH-MSR7BK -> sheepskin pads + Multibrackets MB1893 + Sennheiser Momentum 3 +  Philips Fidelio X2HR/00 + JBL J88 White
MIC :  Tonor TC30 -> Mozos SB38
KEYBOARD : Corsair STRAFE RGB Cherry MX Silent (EU) + Glorious PC Gaming Race Stealth Slim - Full Size Black + PQI MyLockey
MOUSE :  Logitech MX ERGO + 2 x Logitech MX Performance + Logitech G Pro wireless + Logitech G Pro Gaming -> Hotline Games 2.0 Plus + Corsair MM500 3xl + Corsair MM300 Extended + Razer goliathus control
CONTROLLERS :  Microsoft xbox series x controller pc (1VA-00002) -> brainwavz audio Controller Holder UGC2 + Microsoft xbox 360 wireless black + Ravcore Javelin
NET :  Intel x520-DA2 -> 2 x FTLX8571D3BCV-IT + 2 x ASUS ZenWiFi Pro XT12
NAS :  Qnap TS-932X-2G -> Noctua NF-P14s redux 1200 PWM -> Kingston 16GB 2400Mhz CL14 (HX424S14IB/16) -> 9 x Crucial MX500 2TB ->  2 x FTLX8571D3BCV-IT -> 2 x Digitus (DK-HD2533-05/3)
What case, fans and room temperature? What heat spreader if any and location in relation to fans?
I recently moved my 980 Pro froma Fractal R5 to a Torrent compact and dropped temp by about 10°C or so. So that all matters
AMD 9 7900 + Thermalright Peerless Assassin SE
Gigabyte B650m DS3H
2x16GB GSkill 60000 CL30
Samsung 980 Pro 2TB
Fractal Torrent Compact
Seasonic Focus Plus 550W Platinum
W11 Pro
NZXT H710i, NZXT fans?
Default fan placement, 3 x 140 front in take, 1 x 120 rear exhaust.
Ambient room temperature is around 30 - 35?
I'm planning to do a system upgrade sometime this year and change the case to a O11D XL.
Your room is 30-35°C? I think then your temps are relatively good.
Try these:
Gigabyte B650m DS3H
Samsung 980 Pro 2TB
W11 Pro
