Cooling HDD's too much?
Solved by Blue4130,
24 minutes ago, Seb_1 said:Hi, just a quick checkup for my HDD's. I threw together a new server and the HDD's seem to be running a bit cool. Some sources online say that running them too cool wont allow the lubricant to work properly, but I also dont want them to get too hot. So is this ok or should I turn down the fan a bit as right now I have it running at 1600rpm (its a ml120 pro).
Ignore the cache drives as they're purposefully cooled.
Lubricant won't thicken or change viscosity in a detrimental way until well below your current temps (below freezing is when I'd worry) . You're fine.
