Strange network switch issue
4 hours ago, Cramig88 said:How about this, how do i speedtest a local device internally? As in, send random packets to my ps5 from my office pc on 1gbps? I do have a few laptops sitting around doing nothing, so thats always an option. Is there an application to see how fast i can actually push the cables?
You can use iperf with two laptops or a PC and a laptop connected together or through a switch. If you just want to test your cables I'd say it's a good way of doing it without a proper cable tester.
Edit: you can also use https://openspeedtest.com/selfhosted-speedtest
Regarding the orange led link lights, it's almost surely the cables are miswired or a conductor broken inside somewhere, so they work, but only negotiate 100Mbps
If you want to terminate your own cables, there are two common wire patterns called T568A and T568B. You can pick either one, but make sure you do identical on both ends of the cable. You want all your in-suite wiring to be straight through. The cross-overs are seldom used and more so for legacy equipment. Nowadays all networking gear supports auto-mdix which will detect and adjust for straight through or cross-over as needed.
