Best big monitor for WFH
FredC1
Hi,
I work from home full-time and my laptop is a M2 MacBook Air. Not wanting to buy a dock supporting Display Link and be limited to 1080p on a 2 monitors setup I’m looking at buying a 40+ inches monitor (not ultrawide, I presently use a 34 ultrawide and I don’t like it).
The LG 43UN700B is my number one choice at the moment (USB-C, 4K, usb hub) but I wonder if you have other suggestion ?
I’m an ITSM consultant so color accuracy is not really important and I don’t play games so refresh rate isn’t important neither.
LCD ? OLED ? TV as a monitor ? I’d like to hear your thoughts !
Thanks !
For $700, I'd agree with you, go for that.
If you want to spend a little more though, the old 5K LG Ultrafine would give you more screen real estate if you don't use scaling while still retaining the 1 cord I/O. That said, non-scaled 5K at 27" means everything's going to be pretty small...
Also, just be weary that MacOS will foolishly default a 4K screen to 1080p scaling, so everything is going to look STUPID ENORMOUS. at 40+ inches, it's best to turn scaling off completely so it doesn't make UI elements huge and rob you of the screen real estate you're looking for.
I use SwitchResX to do that on my monitors.
Work Rigs - 2015 15" MBP | 2019 15" MBP | 2021 16" M1 Max MBP | Lenovo ThinkPad T490 |
AMD Ryzen 9 5900X  |  MSI B550 Gaming Plus  |  64GB G.SKILL 3200 CL16 4x8GB |  AMD Reference RX 6800  |  WD Black SN750 1TB NVMe  |  Corsair RM750  |  Corsair H115i RGB Pro XT  |  Corsair 4000D  |  Dell S2721DGF  |
Fun Rig - AMD Ryzen 5 5600X  |  MSI B550 Tomahawk  |  32GB G.SKILL 3600 CL16 4x8GB |  AMD Reference 6800XT  | Creative Sound Blaster Z  |  WD Black SN850 500GB NVMe  |  WD Black SN750 2TB NVMe  |  WD Blue 1TB SATA SSD  |  Corsair RM850x  |  Corsair H100i RGB Pro XT  |  Corsair 4000D  |  LG 27GP850  |
43 minutes ago, FredC1 said:
Hi,
Thanks !
A lot to love about this. 4k 60Hz IPS Display and HDR10 (well, sort of at only 400nits ...) The dot pitch is about the same as a 24" 1080p monitor so fonts should look fine in large spreadsheets.
If I wasn't already using 3 x 24" 16x10 1080p ProArt Displays I'd pick that up.
I recommended the previous version to my brother-in-law and he loves it for working from home. He's a Programmer so having the multiple inputs and being able to split-screen is useful for him too. The current model is a bit pricey at the moment here but I've seen it go on sale regularly for $200 off.
FaH BOINC HfM
Bifrost - 6 GPU Folding Rig  Linux Folding HOWTO Folding Remote Access Folding GPU Profiling ToU Scheduling UPS
Systems:
desktop: Lian-Li O11 Air Mini; Asus ProArt x670 WiFi; Ryzen 9 7950x; EVGA 240 CLC; 4 x 32GB DDR5-5600; 2 x Samsung 980 Pro 500GB PCIe3 NVMe; 2 x 8TB NAS; AMD FirePro W4100; MSI 4070 Ti Super Ventus 2; Corsair SF750
nas1: Fractal Node 804; SuperMicro X10sl7-f; Xeon e3-1231v3; 4 x 8GB DDR3-1666 ECC; 2 x 250GB Samsung EVO Pro SSD; 7 x 4TB Seagate NAS; Corsair HX650i
nas2: Synology DS-123j; 2 x 6TB WD Red Plus NAS
nas3: Synology DS-224+; 2 x 12TB Seagate NAS
dcn01: Fractal Meshify S2; Gigabyte Aorus ax570 Master; Ryzen 9 5900x; Noctua NH-D15; 4 x 16GB DDR4-3200; 512GB NVMe; 2 x Zotac AMP 4070ti; Corsair RM750Mx
dcn02: Fractal Meshify S2; Gigabyte ax570 Pro WiFi; Ryzen 9 3950x; Noctua NH-D15; 2 x 16GB DDR4-3200; 128GB NVMe; 2 x Zotac AMP 4070ti; Corsair RM750x
dcn03: Fractal Meshify C; Gigabyte Aorus z370 Gaming 5; i9-9900k; BeQuiet! PureRock 2 Black; 2 x 8GB DDR4-2400; 128GB SATA m.2; MSI 4070 Ti Super Gaming X; MSI 4070 Ti Super Ventus 2; Corsair TX650m
dcn05: Fractal Define S; Gigabyte Aorus b450m; Ryzen 7 2700; AMD Wraith; 2 x 8GB DDR 4-3200; 128GB SATA NVMe; Gigabyte Gaming RTX 4080 Super; Corsair TX750m
dcn06: Fractal Focus G Mini; Gigabyte Aorus b450m; Ryzen 7 2700; AMD Wraith; 2 x 8GB DDR 4-3200; 128GB SSD; Gigabyte Gaming RTX 4080 Super; Corsair CX650m
Thanks guys really appreciate it !
I'll look for a discount and splurge. 😄
