New Build not my first, but first am5 need some help bois ram
Solved by Bradhyo,
3 minutes ago, Harmsway1283 said:You sure can, and your motherboard does have a BIOS flashback button on the rear I/O panel. Even though your motherboard isn’t posting you can still update the BIOS. I would bet that it would solve your problem.
You can find the BIOS revisions on Asus’ webpage for your motherboard. Just google “asus b650m-a ax bios” and it should be the first or second result.
Read the motherboard manual for how to update your BIOS.
Okay ill give it a try
