need help choosing a monitor
dreamcast4599
so im looking to replace my old aging 1080p 60hz monitor, so many people are tilling me to ditch 1080p and upgrade to a 1440p display. but im limited to a budget of 150-200$ which makes upgrading to 1440p impossible
can someone explain to me why so many people are telling me screw 1080p 1440p is better? im so used to gaming at 1080p yet i feel that if i dont jump to 1440p people will hate on me am i missing something is 1080p really limiting my system based on the specs i listed below
specs below
asus crosshair 7 hero X470
ryzen 3900x
4x 8 gig teamgroup 3733mhz ddr4 ram
1000 watt seasonic gold rated psu
6700xt sapphire pulse
1tb sabrent rocket nvme drive
360mm cooler master aio
screen res currently 1080p since i got the monitor for 50$
my current monitor can only to 144hz is using dvi https://www.newegg.com/black-acer-gn246hl-bbid-3d-24/p/N82E16824009642
I believe people like 1440p over 1080p due to the pixel density. As mentioned in the newer short circuit video on the Amazon basics monitor the general rule of thumb is you want around or more than 100 pixels per inch (ppi). So running with a 24 inch monitor at 1080p (92 ppi) is fine. With a 27 inch, 1080p (81 ppi) is okay (that’s what I do) but 1440p (108 ppi) is generally preferable. Any larger than 27 inch you would ideally want to be 1440p or 4k (163 ppi @ 27in).
My PC Specs: (expand to view)
CPU: Intel Core i7-10700K - OC to 5 GHz All Cores
CPU Cooler: Corsair iCUE H115i RGB Pro XT (Front Mounted AIO)
Motherboard: Asus TUF GAMING Z490-PLUS (WI-FI)
Memory: Corsair Vengeance LPX 32 GB (2 x 16 GB) DDR4-3600
Storage: Intel 665p 1 TB M.2-2280 NVME SSD (x2)
Video Card: Zotac RTX 3070 8 GB GAMING Twin Edge OC
Power Supply: Corsair RM850 (2019) 850 W 80+ Gold Certified Fully Modular
Case: Corsair 4000D Airflow
Case Fan 120mm: Noctua F12 PWM 54.97 CFM 120 mm (x1)
Case Fan 140mm: Noctua A14 PWM 82.5 CFM 140 mm (x4)
Monitor Main: Asus VG278QR 27.0" 1920x1080 165 Hz
Monitor Vertical: Asus VA27EHE 27.0" 1920x1080 75 Hz
Mouse: SteelSeries Rival 600 Wired
Keyboard: SteelSeries Apex 5  – (Hybrid Blue Switch)
Headphones: SteelSeries Arctis 9X Wireless - Black
Speakers: Mackie CR3-X 3 Inch Speakers Pair
UPS: APC 1500VA UPS Battery Backup and Surge Protector
@TylerD321 my thing is i want as many frames per second as possible i know at 1080p im more cpu bound i guess im afraid that if i upgrade to 1440p i will loose performance and my fps will struggle
Personally I’d go 1080p at 144hz. I looked around on google and came across this video that shows you how the performance differs at resolutions for the cpu and gpu combo (ignore the i9 stuff).
Remember, you have to always take videos like this with a grain of salt as different motherboards, ram, newer drivers, etc can affect performance but can give you a rough general idea of what to expect.
If someone actually does this, they have no life or their life is so sht that they need to sht on someone else's to feel better about themselves.
There's nothing wrong with 1080p, yes with your current level of hardware, you could play in 1440p somewhat comfortably, you're only missing out on high picture fidelity. That's it, it's that big of a deal.
I'd say, save up a bit more, until $300 and get a decent 27" 1440p 165hz monitor, don't cheap out on a monitor, it literally affects how you perceive the game you're playing.
Not an expert, just bored at work. Please quote me or mention me if you would like me to see your reply. **may edit my posts a few times after posting**
CPU: Intel i5-12400
GPU: Asus TUF RX 6800 XT OC
Mobo: Asus Prime B660M-A D4 WIFI
RAM: Team Delta TUF Alliance 2x8GB DDR4 3200MHz CL16
SSD: Team MP33 1TB
PSU: MSI MPG A850GF
Case: Phanteks Eclipse P360A
Cooler: ID-Cooling SE-234 ARGB
OS: Windows 11 Pro
Pcpartpicker: https://pcpartpicker.com/list/wnxDfv
Displays: Samsung Odyssey G5 S32AG50 32" 1440p 165hz | AOC 27G2E 27" 1080p 144hz
Laptop: ROG Strix Scar III G531GU Intel i5-9300H GTX 1660Ti Mobile| OS: Windows 10 Home
Yeah no forget what people say, with your spec id say its fine to shop 1080p even if it can do a lot on 1440p scenario. But yeah, high quality 1080p240hz experience sits at that 300$ @Dukesilver27- mentioned, XG250 by Viewsonic and GP700 series by LG is one of a good shout for that. But yeah that depends on what you play exactly here, if you are playing semi-competitive or high paced games like CS, id definitely take the motion clarity over resolution all day.
Press quote to get a response from someone! | Check people's edited posts! | Be specific! | Trans Rights
Self Introduction and Current Rig
Hi, have you seen Hoshino Ai recently? Shes not missing, i just thought you should search her on the Internet.
