does the nv7 come with fans
Gin N Rum 5454
Go to solution Solved by TrigrH,
Looks like none are included.
I saw it commented somewhere but I am not sure of the answer and couldn't find it on Phanteks's website. Does anyone know if the new Phanteks NV7 comes with any fans? If so which ones?
Aww okay, can you tell me where you got the information, I can't find much about this case.
a local site:
https://www.pccasegear.com/products/61292/phanteks-nv7-d-rgb-tempered-glass-case-black
1 minute ago, Senzelian said:
^ Can confirm, another local website in Germany says the same.
Thanks
3 minutes ago, Zomeguy said:
I mean there's always Phanteks site. And unfortunately no it does not come with fans.
https://phanteks.com/NV7.html
Like I said, I checked that but couldn't find any information on the fans.
Thanks for the information though.
Generally enthusiast cases like that will not come with fans as its expected you'd be adding your own. That's a case where it really only makes sense if its full of fans as its designed to look good through the glass so just including a couple cheap fans wouldn't really make any sense as they'd just be discarded by the user for 12ish RGB fans the case can fit.
Well I was hoping they'd add some of their new fans the DB30 iirc. But I guess they don't.
Sorry I misunderstood. I thought you meant some local 3rd party site not the German Phantek site.
I hate when companies give different amounts of info on different region sites. Just post it all in all locations. Phantek isn't the only company to do so unfortunately.
Those are $30 premium fans and just including a few would significantly increase the price. If someone didn't want to use D30's, they'd be spending extra for no reason. Included fans are more common on budget cases for new builders. This is really not a new builder kind of case. You're putting a custom loop in this system, right?
No, not going with a custom loop.
The case is kinda a knock off of the lian li o11 dynamic but cost more.
  • 3 weeks later...
Not really a knock off. Its there own take on that certain glass front and side design. And phanteks being phanteks have engineered it really well.
Nope. I hate fish tank cases anyways though so?
CPU-AMD Ryzen 7 7800X3D GPU- RTX 4070 SUPER FE MOBO-ASUS ROG Strix B650E-E Gaming Wifi RAM-32gb G.Skill Trident Z5 Neo DDR5 6000cl30 STORAGE-2x1TB Seagate Firecuda 530 PCIE4 NVME PSU-Corsair RM1000x Shift COOLING-EK-AIO 360mm with 3x Lian Li P28 + 4 Lian Li TL120 (Intake) CASE-Phanteks NV5 MONITORS-ASUS ROG Strix XG27AQ 1440p 170hz+Gigabyte G24F 1080p 180hz PERIPHERALS-Lamzu Maya+ 4k Dongle+LGG Saturn Pro Mousepad+Nk65 Watermelon (Tangerine Switches)+Autonomous ErgoChair+ AUDIO-RODE NTH-100+Schiit Magni Heresy+Motu M2 Interface
