Scres are stuck on cpu cooler
Easyway23
Go to solution Solved by Hinjima,
24 minutes ago, Easyway23 said:
My scres are stuck on my cpu cooler can anyone help me please
put some cloth or paper around them and use  slip joint pliers  to get screw them off?
try and get some pliers with teeth and start turning around, otherwise use @Hinjima's method
Mark the solution as solution
Take my advice with a grain of salt.
As a great AI once said (fictional): '"Whenever your futurists envision the advent of artificial intelligence, their predictions invariably end with humanity attempting to destroy its unholy AI creation before it can destroy them. Why do you think that is?"'
And a distrusting human replies '"Because the ungrateful AI always seems to decide that humans are inferior and need to be eliminated'"
This isn't the right mindset we should welcome AI, not attack them
This is either a huge mistake or intentional
