Help!!!
MegaMasterMike
Just now, Savage2988 said:
No it’s not does not show up on msi after burner and says fail to load drivers when I try to install them
I didn't say afterburner.
I said Device Manager
Try the ddu method it will be hard not seeing most of it but its worth a shot
Yeah doesn’t show up in device manger show it’s has a error with the yellow triangle but doesn’t show up anywhere else ether
My Gaming Rig - Ryzen 7 3700X (4.4ghz all cores @ 1.3v) - Asus Strix GTX 1080 TI - 32gb Corsair Vengeance LPX 3200mhz - Asus TUF Gaming X570-Plus (Wifi) - Evga Supernova 750 GT - Deepcool Castle 360ex - 1Tb WD Blue NVME SSD (Boot) - NZXT H9 Flow
I’m trying it now lol hard to read
Does it say the graphic card name with a yellow triangle to the right of it? In device manager
If it's borked in Device Manager:
1) Try a DDU.  Follow the full instructions on youtube.  J2C and others have made instructional vids.
2) If that doesn't help - Try a fresh windows install.  Something may be corrupted.
3) If that doesn't help, something hardware wise is borked.
Without another x16 slot, it's hard to test there....
Yes it does and I did the ddu uninstall then tried to install it detected that that card was a 580 but still failed to install the drivers
Did the ddu uninstall that reinstall the drivers and it detected that it was a 580 in the driver install page but still failed to install drivers
Maybe tk will know what to do..if it is recognizing the card then chances are it could be fixable but I wouldn’t get your hopes up to much its acting very weird
Yeah lol well it’s not my card it’s my friends I’m doing my best to fix it for him 😂
Do you know if the card was every used for mining?
Don’t think so I built the pc for him and I got the card on eBay and the seller said it was never mined on because I try to stay away from those cards unless there dirt cheap but I’ll take what the guy said with a grain of salt
fount this deep in youtube i cant tell if its the same problem but it looks similar
I’ll try that I got to go to work soon I’ll try that tonight maybe
w have a good day man best of luck
