Pc Building on a budget lmao (yes im very poor lmao) (modified prebuilt)
Zenda64
Specs:
Cpu: Intel core i7 11700f (with stock cooler)
Gpu: ASUS Prebuilt RTX 3060
Ram: 64GB of 3200mhz ddr4
Storage: 500gb m.2 ssd gen 3 1tb HDD
So this is my rig lmao  i took  everything off so my pc wont overheating  in the prebuilt hotbox lmao sorry if its in bad shape i only make 1200$ a month between me my wife and three kids so i have to repair and upgrade slowly lmao
everything is custom besides the gpu and cpu i replaced everything else
All I see is just some scrappy but concious with money pc building.
Nothing wrong with that
You looking for some advice as to what to do next or?
i was just making fun of my setup and how poor i am lmao i wish i could fix all of it but sadly money is always an issue so i joke about it so i dont get depressed lmao
bros got the 4 mesh filters and a cardboard box from Pampers pc case
Dont forget to mark as solution if your question is answered
Note: My advice is amateur help/beginner troubleshooting, someone else can probably troubleshoot way better than me.
- I do have some experience, and I can use google pretty well. - Feel free to quote me I may respond soon.
Join team Red, my apprentice
STOP SIDING WITH NVIDIA
Setup:
Ryzen 7 5800X3DSapphire Nitro+ 7900XTX 24GB / ROG STRIX B550-F Gaming / Cooler Master ML360 Illusion CPU Cooler / EVGA SuperNova 850 G2 / Lian Li Dynamic Evo White Case / 2x16 GB Kingston FURY RAM / 2x 1TB Lexar 710 / iiYama 1440p 165HZ Montitor, iiYama 1080p 75Hz Monitor / Shure MV7 w/ Focusrite Scarlett Solo / GK61 Keyboard / Cooler Master MM712 (daily driver) Logitech G502-X (MMO mouse) / Soundcore Life Q20 w/ Arctis 3 w/ WF-1000XM3
CPU OC: -30 all cores @AutoGhz
GPU OC: 3Ghz Core 2750Mhz Memory w/ 25%W increase (460W)
nothing wrong with this setup. If anything its actually pretty good. I just saw someone asking for a 300 pound budget pc. they can only buy used parts for that
Message me on discord (bread8669) for more help
Current parts list
CPU: R5 5600 CPU Cooler: Stock
Mobo: Asrock B550M-ITX/ac
RAM: Vengeance LPX 2x8GB 3200mhz Cl16
SSD: P5 Plus 500GB Secondary SSD: Kingston A400 960GB
GPU: MSI RTX 3060 Gaming X
Fans: 1x Noctua NF-P12 Redux, 1x Arctic P12, 1x Corsair LL120
PSU: NZXT SP-650M SFX-L PSU from H1
Monitor: Samsung WQHD 34 inch and 43 inch TV
Mouse: Logitech G203
Keyboard: Rii membrane keyboard
Damn this space can fit a 4090 (just kidding)
Btw might have overspent on RAM (not tryna hate)
Current parts list
@filpo well with the ram it took me a year to get all 64 i just bought a 32gig kit and then saved again for another kit lmao
i use that much cause well one i wanted the bragging rights
2. i edit vids alot
3.i also 3d model in unity for vrchat content
but all in all ur not wrong lmao i can least have a over 100 opera tabs open without lagging lmao
2. i edit vids alot
ye for your use case makes more sense, if it was only gaming...
Current parts list
1 hour ago, Zenda64 said:
Specs:
Ive seen worse computer than these that are borderline IED with chinesium "800W" psu with a bunch of modded parts. That CV650 is a really savory pick for a thrift build on 3rd world and definitely couldve gone worse. Good job all around honestly, just need a lot of tidying up.
Press quote to get a response from someone! | Check people's edited posts! | Be specific! | Trans Rights
I am human. I'm scared of the dark, and I get toothaches. My name is Frill. Don't pretend not to see me. I was born from the two of you.
  • 2 weeks later...
If it works, it works, nothing bad about that.👍
Gaming With a 4:3 CRT
System specs below
CPU: AMD Ryzen 7 5700X with a Noctua NH-U9S cooler
Motherboard: Gigabyte B450 Aorus M (Because it was cheap)
RAM: 32GB (4 x 8GB) Corsair Vengance LPX 3200Mhz CL16
GPU: EVGA GTX 980 Ti SC Blower Card
HDD: 7200RPM TOSHIBA DT01ACA100 1TB, External HDD: 5400RPM 2TB WD My Passport
SSD: 1tb Samsung 970 evo m.2 nvme
PSU: Corsair CX650M
Displays: ViewSonic VA2012WB LCD 1680x1050p @ 75Hz
Gateway VX920 CRT: 1920x1440@65Hz, 1600x1200@75Hz, 1200x900@100Hz, 960x720@125Hz
Gateway VX900 CRT: 1920x1440@64Hz, 1600x1200@75Hz, 1200x900@100Hz, 960x720@120Hz (Can be pushed to 175Hz)
Keyboard: Thermaltake eSPORTS MEKA PRO with Cherry MX Red switches
