Son's phone stopped charging
My son has my old samsung A70 it stopped charging so i replaced the port and the fault still persisted. The phone started charging again after attempting to charge it multiple times, this has been the case for the past two weeks which lead me to belive that the original port wasnt actualy defective (i have since disposed of the port so i cannot swap it back). My next thought is it could be a dead battery. I visualy inspected the battery while i had the phone open and it was not swolen at all. At this moment in time i cannot afford a new phone for him. I am willing to try a replacemet battery but that is what bring me here. Before i throw more money at it i am asking for possible fixes or should i chance buying a battery?
I have tried multiple chargers with various wattages (25W being the max) and multiple cables, C - C and A - C.
The phone currently has around 40% charge and functions as normal. So i can probably rule out a motherboard problem.
My fear is, that he has tried to use his switch charger to charge his phone. I have told him to only ever use that charger for the switch as i am unsure of where the smart power delivery is (charger or device).
any advice is appricated. even if it is to chance a new battery.
Thank you
Thank you
How much is a replacement battery?
Not knowing your situation, but if a phone is that important (and to many it's more important than life itself), can you find yourself to have $160  or even a used Ebay special?  USA price, that is.
Buy OnePlus Nord N200 5G | OnePlus United States
Basically, a kid and his phone is a peace of mind these days for us parents.  Again, missing a lot of info here but you're going thru a shitload of frustration with that old thing and there is no guarantee any try will fix it.
Again, just a suggestion while not having all the facts.  Hope you get a solution soon either way.
"Do what makes the experience better" - in regards to PCs and Life itself
Onyx - AMD Ryzen 7 7700x (-30 PBO, 5.45GHz all core) - MSI 6900xt Gaming X Trio - Gigabyte B650 AORUS Pro AX - G. Skill Flare X5 DDR5-6000 32GB (EXPO) - Samsung 980 1TB x3 - Super Flower Leadex V Platinum Pro 850 - EK-AIO 360 Basic - Lian Li Lancool II Mesh C - AOC AGON 35" 3440x1440 100Hz - Mackie CR5BT - Corsair Virtuoso SE - Cherry MX Board 3.0 - Logitech G502 - THANK YOU, MICROCENTER for the FREE DDR5 and $629 6900xt!!!!
Emma : i9 9900K @5.1Ghz - Gigabyte AORUS 1080Ti - Gigabyte AORUS Z370 Gaming 5 - G. Skill Ripjaws V 32GB 3200Mhz - 750 EVO 512GB + 2x 860 EVO 1TB (RAID0) - EVGA SuperNova 650 P2 - Thermaltake Water 3.0 Ultimate 360mm - Fractal Design Define R6 - TP-Link AC1900 PCIe Wifi
Plex : Ryzen 5 1600 - Gigabyte B450M-DS3H - G. Skill Ripjaws V 16GB 2400Mhz - MSI 1050Ti 4GB - 840 EVO 256GB + Toshiba P300 3TB - TP-Link AC1200 PCIe Wifi - Cooler Master MasterWatt Lite 500 - Antec Nine Hundred - Spectre 24"
Raven:  Intel i3 10100F - ASRock H410M-HDV - G. Skill Ripjaws V 16GB 2666Mhz - MSI 1050Ti 4GB - Inland 256GB SSD + Crucial MX500 1TB - TP-Link AC600 USB Wifi - Gigabyte GP-P450B PSU -  Cooler Master MasterBox Q300L -  Samsung 27"
OnePlus 11 - 16GB RAM, 256GB NAND, Eternal Green
Other Tech:
- Ubiquiti Amplifi HD mesh wifi
Thank you for the quick reply, he is 13 and needs one for school. A battery is around £10ish. I could get a budget phone but that would cost lots more than a whole device. I just don't want to risk throwing more money it if its a lost cause.
Did you check it with a voltmeter?
Having a voltmeter is more important these days than having a phone and also a lot cheaper too.
I didn't my daughter destroyed one of the probes and I haven't picked a new set up yet.
Check, sometimes an entire meter with probes costs less than just probes.
Here I could get a meter with probes for less than $10 ($5 US) and probes about $30 !!!
Daft? Yes.
