Dear tech gurus,
For a while now ive been encountering an issue when gaming. At some point during my sessions my pc will randomly freeze and restart by itself. When looking at  Eventviewer i see multiple warnings with the source "WMI". The errror message reads :" A provider, IntelMEProv, has been registered in the Windows Management Instrumentation namespace root\Intel_ME to use the LocalSystem account. This account is privileged and the provider may cause a security violation if it does not correctly impersonate user requests."
https://linustechtips.com/topic/1494243-need-help-tech-gurus/
Full PC specs?
Have you monitored your temps when the crash occurs?
Are all of your drivers including chipset and bios up to date?
Main Desktop: CPU - i9-14900k | Mobo - Gigabyte Z790 Aorus Elite AX | GPU - PNY Gaming OC RTX 5080 16GB RAM - Corsair Vengeance Pro RGB 64GB 6400mhz | AIO - Arctic Liquid Freezer III 360mm | PSU - Corsair RM1000X | Case - Hyte Y40 - White | Storage - Samsung 980 Pro 1TB Nvme /  Sabrent Rocket 4 Plus 4TB Nvme / Samsung 970 EVO Plus 2TB Nvme / Samsung 870 EVO 4TB SSD / Samsung 870 QVO 2TB SSD/ Samsung 860 EVO 500GB SSD|
Phone: Samsung Galaxy S26 Ultra - Black 256GB |
https://linustechtips.com/topic/1494243-need-help-tech-gurus/#findComment-15843809
 My specs are:
i9 10900
rtx 3080
not sure about the psu but its 850 80+ gold
b560m ds3h v2
32gb of 3200 mhz ram
My temps are low, atleast on the gpu side of things. Ill need to check cpu.
Im using intel upgrade assistent to update drivers and ive got all the most recent stuff.
Edit: Cpu seems to be running at about 60-70° under stress.
https://linustechtips.com/topic/1494243-need-help-tech-gurus/#findComment-15843844
IntelME is the Intel Management Engine, typically you need to install the driver for it from the motherboards manufacturer webpage in the support section. The Intel Upgrade Assistant also will not update the bios for the motherboard. So if you haven't been getting the drivers and bios updates from the motherboards support page they're most likely out dated or wrong. I would update all that you can and see if there are still issues.
https://linustechtips.com/topic/1494243-need-help-tech-gurus/#findComment-15843850
  • 4 months later...
