Hi everyone I was wondering for when the time comes what do you guys use to clean your pc and do I need to unplug the fans when I do this or just make sure the power is off any help would be appreciated , I put a pic of the case also to see which would work best for it
https://linustechtips.com/topic/1494111-cleaning-pc/
When cleaning, I disassemble all parts, including fans.
I use compressed air, when blowing on fan, I stop the blades from spinning by holding the middle part of the fan.
Sometimes I use fine brush lightly to loosen some dusts that doesn't get removed by the blow of air.
Then I use a microfiber cloth to clean things like cables, connectors, or some surfaces like GPU backplate, fan blades. Sometimes combined with IPA if needed.
I'd use a compact air blower to save money from repeatedly buying compressed air, but they're expensive for really questionable quality & safety in my country.
Refresh before you reply
https://linustechtips.com/topic/1494111-cleaning-pc/#findComment-15843001
Some Iso alcohol and paper towels. Don't need to unplug fans but make sure power is off.
My First PC
CPU: Ryzen 5 5600x
Cooler: Asus TUF Gaming LC240
Motherboard: Asus ROG Strix B550-f gaming
RAM: 4x8 GB Corsair Vengeance RS (3200 MHz, CL16)
Storage: 1tb Samsung 980 Pro
Graphics Card: Asus Dual RTX 2060 OC
Case: Deepcool Matrexx 50
Power Supply: Corsair RM650x
Headset: Razer Blackshark V2
Keyboard: Corsair K70 Pro Mini (Speed Silver switches)
Mouse: Razer Viper Mini
Only changes I have made is I sold the 2060 for $235 AUD and bought a Powercolor Red Devil 6700 XT for $400 second hand (it was barely used, think I scored a deal on Ebay with that).
I love Photography (Using a Canon 60D)
Love F1, my favourite team is Ferrari and my favourite driver is Leclerc
https://linustechtips.com/topic/1494111-cleaning-pc/#findComment-15843002
Like a devac 500 or something are they safe for cleaning pc I am not very good with pcs mate lol I had to get mine built for me by a guy I know who builds them lol
https://linustechtips.com/topic/1494111-cleaning-pc/#findComment-15843005
Datavac, Lots of people uses it.
But I think I heard somewhere it's best to use it with a grounded outlet to prevent static buildup jumping to your parts.
Anyway if you use compressed air or air blower, just make sure you stop the fan from spinning.
https://linustechtips.com/topic/1494111-cleaning-pc/#findComment-15843008
Yes, it's safe.  U have used vacuums, blowers, rags, alcohol, etc.
Power off, unplug, all good.  They're not fragile, just don't leave things wet.  Air into fans is fine, they spin an won't break if you spin them backward even.
Gotta get your fear of PC's conquered.
No you don't.  Fans aren't fragile, they can free spin without damage.
Onyx: Ryzen 7 7800X3D / Gigabyte B650 AORUS Pro AX / ASRock Taichi 7900xtx OC / G. Skill Flare X5 6000CL36 64GB (4x16GB) / Samsung 980 1TB x3 / Super Flower Leadex V Plat Pro 1000 / EK-AIO 360 Basic w/ Silent Wings fans / Fractal Design North XL (black mesh) / LG - UltraGear 45" OLED QHD 240Hz / Mackie CR5BT / SteelSeries Arctis Nova Pro / Cherry MX Board 3.0 / Logitech G502 - https://valid.x86.fr/my9nnr
7800X3D - PBO +200, CO -30 all cores, 4.90GHz all core, 5.05GHz single core, Cinebench 23: 18401 multi, 1779 single
Khaleesi: Ryzen 5 5600X3D (+200, -30) - ASRock B550M Pro4 - G. Skill Ripjaws V 16GB 3200CL16 - Asus Prime 9060XT 16GB - Samsung 980 1TB + Crucial MX500 1TB - Cudy AX3000 PCIe Wifi 6 - EVGA SuperNOVA 650 P2 - Thermalright Frozen Notte RGB 360 White V2 - NZXT H6 Flow RGB White - LG 34" 3440x1440
NAS/Plex/Game Server  Ryzen 9 5900XT 16c/32t - Gigabyte B550M AORUS Elite AX - TeamGroup T-Force Vulcan 64GB 3200CL16 - MSI 1050Ti 4GB - Crucial P3 Plus 500GB + TeamGroup MP44L 2TB (Game) + WD Red Plus 4TBx2 (Plex) - TP-Link AC1200 PCIe Wifi - EVGA SuperNOVA 650 P2 - Thermalright Peerless Assassin 120SE - ASUS Prime AP201 - Currently Hosting: Enshrouded x2, Hytale, Icarus, Windrose. Project Zomboid, Dune Awakening.
Sage: Ryzen 7 7800X3D (+200, -30) - Gigabyte B650 Gaming X V2 - ASRock Steel Legend 7900GRE - G. Skill Flare X5 32GB 6000CL32 - TeamGroup MP44L 2TB - Super Flower Leadex Platinum SE 1000w - NZXT H5 Elite
Emma: i9 9900K @5.2Ghz - Gigabyte Z370 AORUS Gaming 5 - MSI 6900XT Gaming X Trio - G. Skill Ripjaws V 32GB 3200CL16 - 750 EVO 512GB + 2x 860 EVO 1TB (RAID0) - Super Flower Combat FG 850w - Thermaltake Water 3.0 Ultimate 360 - Fractal Design Define R6 - TP-Link AC1900 PCIe Wifi
Extra parts: ASUS 6650XT - Gigabyte 1080Ti - Cooler Master Q300L - Gigabyte 450w PSU - Super Flower Leadex V Plat Pro 850w
OnePlus Ecosystem:
OnePlus 11 5G - 16GB RAM, 256GB NAND, Eternal Green. OnePlus Watch 2 - Radiant Steel, OnePlus Buds Pro 2 - Eternal Green
3D Printing:
Bambu Lab X1 Carbon, AMS, AMS2 Pro (thank you MicroCenter!)
Other Interesting Tech:
- 2021 Volvo S60 Recharge T8 PHEV Polestar Engineered - 415hp/495tq 2.0L 4cyl. turbocharged, supercharged and electrified.
https://linustechtips.com/topic/1494111-cleaning-pc/#findComment-15843011
Datavac is crazy expensive where I live atleast. I preffered compressed air.
My First PC
CPU: Ryzen 5 5600x
https://linustechtips.com/topic/1494111-cleaning-pc/#findComment-15843020
The issue with spinning fans with compressed air isn't damaging the fan(although you shouldn't be running a fan higher than its max RPM anyway), but if the fan spins freely it can actually generate an electrical current which can cause issues elsewhere in your PC.
https://linustechtips.com/topic/1494111-cleaning-pc/#findComment-15843021
Yeah I know lol it’s just dead expensive well least I have warranty lol so using a detavac is will be okay aslong as it’s all powered off do I need to tape the fans or will leaving them be fine yeah @Crunchy Dragon
https://linustechtips.com/topic/1494111-cleaning-pc/#findComment-15843030
What would you recommend @Crunchy Dragon
https://linustechtips.com/topic/1494111-cleaning-pc/#findComment-15843032
i've actually tested this, with a 600 watt datavac (basicly handheld vaccuum cleaner), on every fan i own. and the worst i got was a 40mm fan spinning so hard it was about ready to leave it's bearings... and it made like -0.5 volts, which clamped right to zero if i stuck a 1K resistor across it (to simulate what any sort of motherboard connection would do)
if you find any fans that do generate noteworthy power when you rev them with canned air, let me know, so i can avoid them because they are designed worse than a fan series that's literally called "xilence white box"... because they come in a white unbranded box.
on topic: i generally hold the fans by the hub to stop them from spinning up, but that's because any airflow going into spinning that fan isnt going into blowing dust off the blades.
beyond my trusty datavac (which.. dont buy them, they're overpriced as fuck, mine came out the box with rust. and a cardboard "seal" supposed to hold things airtight against a motor that literally gets burning hot in use.) i also have -the cheapest soft-bristle paintbrush at the local hardware store-.
and that's basicly what you need: something to create airflow to blow the loose stuff away, and something to grind off the stuff that stuck down. you could dust your computer with a bicycle pump if you feel especially green today.
https://linustechtips.com/topic/1494111-cleaning-pc/#findComment-15843046
So would you say avoid the devac 500 what else would you recommend in its place @manikyath
https://linustechtips.com/topic/1494111-cleaning-pc/#findComment-15843069
i dont think it has a ground plug? just 2 prong.
https://linustechtips.com/topic/1494111-cleaning-pc/#findComment-15843077
a paint brush. the extremely soft bristle ones.
last time i took my computer out for cleaning i just put it out in the wind because i couldnt be arsed to get an extension cord for the datavac. just brush the dust up and the wind carries it away to the neighbors.
as long as you arent cleaning out several computers per day, it's not worth the investment of a propper air blower, especially because you need the paint brush to get the dust loose either way.. so you may as well just not.
https://linustechtips.com/topic/1494111-cleaning-pc/#findComment-15843083
Idk man, I never used one before. Too expensive for me 🤣
Not like the brand exist in my country anyway
I just heard that using these air blower to clean PC may build up static and that it can jump to the PC.
https://linustechtips.com/topic/1494111-cleaning-pc/#findComment-15843106
ya they use to be cheap... i spent like $80 on mine and im guessing there like $150+ now...  a cheap blow dryer could probably work.
ya could also be a myth too 🤷‍♂️
https://linustechtips.com/topic/1494111-cleaning-pc/#findComment-15843118
I think you need a different motor that can covert the fan movement back to energy.  Standard fans shouldn't do this.
OnePlus Ecosystem:
3D Printing:
https://linustechtips.com/topic/1494111-cleaning-pc/#findComment-15843423
I use a all purpose cleaner for the outside of the case to wipe it down. Glass cleaner for the class. Datavac for cleaning all the dust from inside the case and a detailing brush to help agitate dirt and dust where needed. Usually can get it all clean in about 10-15 minutes
Main Rig CPU: AMD Ryzen 7 5700x GPU: Asus TUF Gaming RTX 3080 OC MBASUS AM4 TUF Gaming X570-Plus RAM: 64GB Corsair Dominator Platinum 3200 CPU Cooler: Cooler Master Master Liquid LC240E SSD: Crucial 250gb M.2 + Crucial 500gb SSD + 4TB Crucial SSD HDD:None PSU: Thermaltake Toughpower Gran RGB 850W 80+ Gold Case: Corsair Carbide 275R KB: Glorious GMMK 85% MOUSE: Razer Naga Trinity HEADSET: Go XLR with Shure SM7B mic and beyerdynamic DT 990
unRAID Plex Server CPU: Intel i7 6700 GPU: Nvidia Quadro P2000 MB: Asus B150M-C RAM: Crucial Ballistix 32gb DDR4 3000MT/s CPU Cooler: Stock Intel SSD: Western Digital 500GB Red HDD: 4TB Seagate Baracude 3x 4TB Seagate Ironwolf PSU: EVGA BT 80+ Bronze 450W Case: Cooler Master HAF XB EVO KB: Cheap Logitech KB + Mouse combo
https://linustechtips.com/topic/1494111-cleaning-pc/#findComment-15844868
Unless you're a heavy smoker, all you need to do is simply blow air in the system to remove the dust once in a while.
You need to prevent the fans from spinning, use a screw driver, put it in to stop the blades from spinning and blow away. For the PSU fan, same principle, but use a thick plastic tie wrap or something else that's insulated, you don't want to poke in there with metal.
Personally, what I do is typically pass a thin plastic/silicone tube(those re-usable straws) through all my fans and once they are all stopped, I blow away. That is all that is needed for me, since I don't smoke or vape or anything like that. I do that like once a year for the inside of the PC. I have dust filters on all intakes, so I clean those like every 2 months or so.
https://linustechtips.com/topic/1494111-cleaning-pc/#findComment-15844955
Do smoke a vape at times but it’s blown at the window or at the window stopped smoking at 19 for anyone here don’t start it lol worst thing ever cheers for the hep hair cleaned the dust filters there is with water letting them dry
https://linustechtips.com/topic/1494111-cleaning-pc/#findComment-15845540
