Depends on how the fans are oriented. My fans are oriented as exhaust, so they will push/pull(depending on the location on the radiator) air through the radiator. Technically, with the fans being used as exhaust, they can still pull air into the chassis, but that's primarily done by the intake fans in my case.
Edited by Godlygamer23
1 minute ago, jaslion said:
Yes but it will be hotter air.
Front mount aio = colder cpu but everything else runs hotter
Top mount or even rear mount = colder everything else but cpu runs hotter
But why are you getting an aio in the first place? if you are looking for raw cooling performance then arctic liquid freezer ii or an ek aio, but id only see aios being justifiable once you start cooling things like a 13700k or up cause aircoolers like the peerless assassin or even silver soul 135 are dirt cheap (41$ and 30$ respectively) and those are both dual towers so they will crush any meekly 240 aio
Top mount depends if you do intake top aio + front intake then you get the best of both worlds.
Right since the hot aio air will be exhausted alot quicker and not hit anything aside from the cpu vrm area since its closer to the rear of the case
Guess theres always the best of both worlds, but no 360mm top mount on some cases
16 minutes ago, BlubFish_ said:
Just a quick question does an AIO still draw in air for the rest of the case
I think it does but for all i know it doesn't
cause this is going to be my first water cooling build
Depends where you put the AIO.  Do you understand how fans work?  If so, you can answer this for yourself.
Onyx: Ryzen 7 7800X3D / Gigabyte B650 AORUS Pro AX / ASRock Taichi 7900xtx OC / G. Skill Flare X5 6000CL36 64GB (4x16GB) / Samsung 980 1TB x3 / Super Flower Leadex V Plat Pro 1000 / EK-AIO 360 Basic w/ Silent Wings fans / Fractal Design North XL (black mesh) / LG - UltraGear 45" OLED QHD 240Hz / Mackie CR5BT / SteelSeries Arctis Nova Pro / Cherry MX Board 3.0 / Logitech G502 - https://valid.x86.fr/my9nnr
7800X3D - PBO +200, CO -30 all cores, 4.90GHz all core, 5.05GHz single core, Cinebench 23: 18401 multi, 1779 single
Khaleesi: Ryzen 5 5600X3D (+200, -30) - ASRock B550M Pro4 - G. Skill Ripjaws V 32GB 3200CL16 - Asus Prime 9060XT 16GB - Samsung 980 1TB + Crucial MX500 1TB - Cudy AX3000 PCIe Wifi 6 - EVGA SuperNOVA 650 P2 - Thermalright Frozen Notte RGB 360 White V2 - NZXT H6 Flow RGB White - LG 34" 3440x1440
NAS/Plex/Game Server  Ryzen 9 5900XT 16c/32t - Gigabyte B550M AORUS Elite AX - TeamGroup T-Force Vulcan 128GB 3200CL16 - MSI 1050Ti 4GB - Crucial P3 Plus 500GB + TeamGroup MP44L 2TB (Game) + WD Red Plus 4TBx2 (Plex) - TP-Link AC1200 PCIe Wifi - EVGA SuperNOVA 650 P2 - Thermalright Peerless Assassin 120SE - ASUS Prime AP201 - Currently Hosting: Enshrouded x2, Hytale, Icarus, Windrose, Project Zomboid, Dune Awakening.
Sage: Ryzen 7 7800X3D (+200, -30) - Gigabyte B650 Gaming X V2 - ASRock Steel Legend 7900GRE - G. Skill Flare X5 32GB 6000CL32 - TeamGroup MP44L 2TB - Super Flower Leadex Platinum SE 1000w - NZXT H5 Elite
Emma: i9 9900K @5.2Ghz - Gigabyte Z370 AORUS Gaming 5 - MSI 6900XT Gaming X Trio - G. Skill Ripjaws V 32GB 3200CL16 - 750 EVO 512GB + 2x 860 EVO 1TB (RAID0) - Super Flower Combat FG 850w - Thermaltake Water 3.0 Ultimate 360 - Fractal Design Define R6 - TP-Link AC1900 PCIe Wifi
Extra parts: ASUS 6650XT - Gigabyte 1080Ti - Cooler Master Q300L - Gigabyte 450w PSU - Super Flower Leadex V Plat Pro 850w
OnePlus Ecosystem:
OnePlus 11 5G - 16GB RAM, 256GB NAND, Eternal Green. OnePlus Watch 2 - Radiant Steel, OnePlus Buds Pro 2 - Eternal Green
3D Printing:
Bambu Lab X1 Carbon, AMS, AMS2 Pro (thank you MicroCenter!)
Other Interesting Tech:
- 2021 Volvo S60 Recharge T8 PHEV Polestar Engineered - 415hp/495tq 2.0L 4cyl. turbocharged, supercharged and electrified.
I used strong fans on my AIO in both front and top mount, but I don't recall ever feeling warm air coming off the rad. I was using 120x38s on a 240 rad, both in push and push/pull, because I had 4 😄
AMD R9 9900X | Thermalright FW Pro Black, 3x TL-B12E | Asus Strix X670E -F | 64GB G.Skill 6000C26
Zotac 4070 Ti Trinity OC | WD SN850, SN850X, 2x SN770 | Seasonic Vertex GX-1000 | ProArt PA602
Adcom GFP-345, Adcom GFA-555, S.M.S.L D1+PS100, Cerwin-Vega! CLSC-15, Monster HDP-1800
There are a fair few cases that have 360 top mounts tho
but but... this config would blow the socks, pants and shirt off an towercooler in performance 🤔
So for a ryzen 5 7600 an air cooler should be enough then
It was pretty good.
You know what wasn’t good?
Permeation.
Yup.
Yep
Also why dont you go get the 7700 instead? 2 more cores and no need to buy a cooler cause the wraith prism is a solid stock cooler, if youve hit budget ceiling already then you can cut cost on something else (most common overspending areas = board, case, psu, high end gen4 ssd) assuming your build isnt fully cost optimized yet
