CPU temps in HWINFO jump to 100c+ then settle
39 minutes ago, ImPruhVise said:Hey Y'all
I'm comfortably set up on my new PC now after dealing with some issues (SSD died)
I've installed HWINFO to check if everything is all right. I noticed every time I launch Battlefield 2042 the CPU temps JUMP to 100c+ for a split second and settle. (the spikes you see on the graph are only at 75c) The 100c+ never actually show up on the graph. During gameplay my temps are fine other than the initial jump. And in other games I don't notice anything like this.
I am wondering if this is a glitch with HWINFO as it seems unusual. Should I be concerned about this?
Specs:
i9-12900kf
MSI MAG CORE AIO Cooler 240R V2
RTX 3080ti
64 GB DDR5 RAM 4800mhz (Weird ADATA model)
WD_BLACK SN850x 1tb
MSI z690-a wifi motherboard
This isn't a problem that's just intel's boost method and the heat of the 12900k. Also I hate to say it but I don't think any cooler (apart from LN2) can tame the beast
