4 minutes ago, Kyrpousin said:
The voltage of my Ryzen 5600G drops to almost 0.070. Is this thing normal?
Which voltage and what software are you using to monitor it? Most voltages I'm aware of shouldn't get that low and would instantly lock up the system if they did, so I'm assuming that this is likely a software reading issue.
Also is there a reason you included that audio recording or was that an accident?
I used Aida64, cpuz and ryzen master and all almost the same.
The audio recording was an accident.
