Will corsair Rm1000x shift fit in lianli lancool 3?
Solved by SorryBella,
26 minutes ago, Ulitochnik said:Who to trust?
Tight fit at only 40mm tolerance. If you struggle with the cable management, you can just remove both of the 3.5 inch bay. Theyre removable.
Featured Topics
pchelp ·
Posted in Phones and Tablets0 -
2
4
5
6
Ettan-999 ·
Posted in Power Supplies1 -
Trembletop ·
Posted in CPUs, Motherboards, and Memory1 -
3
ki8aras ·
Posted in Graphics Cards15 -
play_circle_filled
Latest From Tech Quickie:
Ethernet Is Named After Something Really Dumb (and other tech stories)
