I've just built a computer with the Asus Prime z790 P motherboard and have been having a bit of trouble with blue-screening (System thread exeption not handled). After a bit of googling i figured it might be the drivers messing with me and noticed the following warnings in the device manager (see picture).
Is this what might be messing with me? I can't seem to figure out which drivers need updating if so, or if it might be a hardware issue.. any tips?
Specs are as follows:
13th Gen Intel(R) Core(TM) i5-13600KF   3.50 GHz
Asus prime z790-P D4
Kingston NV2 M.2 1TB
2x 8GB Corsair Vengeance RG
RTX 3070 Ti
Arctic Liquid Freezer 2 240 A-RGB
https://linustechtips.com/topic/1491822-pci-problems/
An unknown device generally means you haven't installed the necessary driver yet. Check the driver page for the motherboard, see if you find one that belongs to a device you don't see in the list: https://www.asus.com/motherboards-components/motherboards/prime/prime-z790-p/helpdesk_download/?model2Name=PRIME-Z790-P
https://linustechtips.com/topic/1491822-pci-problems/#findComment-15827045
