contact dell, they can sell you the parts
I want to upgradethe CPU on my dell latitude E5530 from an Intel i3-3110M to a Intel i7-3520M is the i7 compatible with the laptop please help.
http://processors.findthebest.com/compare/968-992/Intel-i3-3110M-vs-Intel-i7-3520M
You're wanting to skip generations in CPU architecture. I wouldn't recommend it and doubt without a lot of work it's possible. CPU is almost for sure soldered to the board.
Please quote/tag ( Found by typing @DarrenP) In all posts directed at me. I do not check my current content.
Intel Core i7-4790K - Gigabyte Z97X-UD5H-BK - 16GB Corsair Vengeance Pro 1866Mhz - EVGA GTX 980 - 256GB MX100 - 2TB WD RED - 900D - H100I - Corsair HX1050 - DNS 320L 2x2TB Seagate Barracuda
Do not go down that path. Procuring parts might be as expensive as buying a new low to mid tier laptop.
1- That CPU has 2 possible forms FCBGA1023 (BGA; soldered on board) and FCPGA988 (socket 988)
2- I think that laptop is socket 988 so yeah, a i7-3520M could be an option for it, since it's the same TDP
3- You want to get a new laptop, usually laptop CPUs bought separately are expensive
4-Compatibility: that CPU should be compatible it's; CPUs that are totally compatible (going to put what I find):
-i5 3210m
-i7-3520M
-Dell's website (
http://www.dell.com/es/empresas/p/latitude-e5530/pd) (rPGA988B, I can't confirm this, but according to this it should, then it should support (if that one you've has a HM77 chipset) the next cpus: http://www.cpu-upgrade.com/mb-Intel_%28chipsets%29/HM77_Express.html (look up to 35xx versions, ignoring Y and U versions)):
-i7-3540M
-i5-3380M, i5-3340M, i5-3230M
Higher versions of 3rd gen (36xx and higher) may work and may not... but you don't wanna try
5- That laptop seems to work only with iGPU, so if your issue are graphics, you need to buy a new laptop
But its BGA and he needs a new board that actually fits the laptop....
I really doubt he can find dell parts. The dell boards on eBay are for desktops and not proprietary boards.
Are you sure it'll be compatible? I mean that it'll obviously be pin-compatible, but that doesn't mean the mobo works with it...you know how picky Dell's boards are with GPUs.
Plus, where would anyone find a tray mobile processor that has such a little-known PGA socket?
