Hi all,
I've just built my pc with a 13400F (it was on sale), 32 GB of Corsair Vengeance RGB Pro and a MSI VENTUS 3X OC GeForce RTX 3070 Ti in a FD Torrent Compact, I'm still running the stock Intel cooler but was thinking of upgrading it to something but I'm not sure what to go with.
I'm buying from the UK and not looking to spend more than £50 max.
As another thing, I haven't added any more fans than came with the case, so it's just the 2 180mm at the front, is this enough?
Thanks for the help
Edited by DaveThe6th
Updated with more information
https://linustechtips.com/topic/1487003-cpu-cooler-upgrade/
What ram are you using?
Where are you shopping/ located? Budget? What's are you aiming to improve?
https://linustechtips.com/topic/1487003-cpu-cooler-upgrade/#findComment-15792871
Oh sorry, I'll update the topic with that info. First time posting and all that but hopefully that's more helpful now
https://linustechtips.com/topic/1487003-cpu-cooler-upgrade/#findComment-15793733
The stock case fans should be plenty for cooling.
SE-214-XT is a decent upgrade: https://uk.pcpartpicker.com/product/Zr8bt6/id-cooling-se-214-xt-682-cfm-cpu-cooler-se-214-xt-argb
If you don't mind spending more , the AG500 would have more headroom for a potential upgrade: https://uk.pcpartpicker.com/product/pHfnTW/deepcool-ag500-bk-argb-6788-cfm-cpu-cooler-ag500-bk-argb
https://linustechtips.com/topic/1487003-cpu-cooler-upgrade/#findComment-15794264
