ALERT - Linus Tech Tips, Tech Quickie, Tech Linked Youtube Channels Hacked ×
Powering Monitor with DC jack over usb-c
Johnny73
 Share
Go to solution Solved by mariushm,
There are small devices which you can connect to a USB type-C output and "tell" the charger to configure the voltage to a specific level , like 5v, 9v, 12v, 15v, 20v, or something in-between.
Just the fact it has a barrel jack connector doesn't tell me anything - you need to know the voltage the monitor expects on that barrel jack connector. It would probably be 12v or 18v or something like that, because it would mean they can use mass produced power supplies (laptop adapter style bricks)
Look on the actual power supply that came with the monitor, it will say the voltage and current it's designed for.  Voltage x Current = Power, but the adapter will be designed to supply more than what monitor consumes on average, and it's designed to support monitor at 100% brightness, with devices plugged in usb ports that consume a few watts, and so on ...
For example, here's one of those adapters :  https://www.amazon.com/Type-C-Trigger-Module-Supports-Output/dp/B08LDJBN8P
By connecting the appropriate pads with a blob of solder, you tell the chip on the board to tell your usb type c to change the voltage to the one you configured, otherwise the usb charger will output 5v. See picture below
Another example of such adapter/module/board, same concept, solder pads to set the voltage : https://www.amazon.com/Trigger-Adjustable-Voltage-Module-Default/dp/B0B688SKNK/
And these are "hardcoded" to 19v or 12v and they're 2.1 ID, 5.5mm OD :
19v:
https://amazon.com/Cablecc-Adapter-Emulator-Trigger-4-01-3mm/dp/B07W5M54PV/
https://www.amazon.com/Rectangle-Adapter-Emulator-Trigger-5-52-1MM/dp/B07SJ9SB6Y/
12v
https://www.amazon.com/NFHK-5-5x2-1mm-Adapter-Emulator-Trigger/dp/B0B9RDJ1YK/
Then you solder a cable with the right barrel jack plug to the holes at the end of the board (you see + and - there) and you're in business.
Examples of cables with plug and loose wires or other connector (you could cut to get wires) at the other end : https://www.digikey.com/short/dr2301w8
Most common formats are 2.1mm ID (inner diameter), 5.5mm OD  (outer diameter)  and 2.5mm ID / 5.5 mm OD
If the monitor wants 18v, it will probably work with 15v, but would be risky to give it 20v. If it's 19-19.5v, 90% sure it will work with 20v from your usb charger.
Hi, I wanted to power my monitor over usb-c. (I have charger with enough power and amps)
It's LG ULTRAGEAR WK95U and It uses a 5.5mm DC barell plug, so If I used proper cable could It be powered over usb-c?
Thanks
Monitor requires 120VAC
No.
Main System (Byarlant): Ryzen 7 3800XT | Asus B350-F Strix | EK 240mm Basic AIO | 16GB G.Skill DDR4 3200MT/s CAS-14 | PNY RTX 3060 Ti XLR8 Gaming Revel Epic-X | Samsung 960 PRO 512GB / Samsung 970 EVO 500GB / Crucial MX500 2TB / Crucial MX500 500GB / WD White 7200RPM 8TB | Corsair RM750X | Intel X540-T2 10G NIC | Inateck USB 3.0 Card | Hyte Y60 Case | Dell U3415W Monitor | Microsoft Modern Keyboard
Laptop (Narrative): Lenovo Flex 5 81X20005US | Ryzen 5 4500U | 16GB RAM (soldered) | Vega 6 Graphics | SKHynix P31 1TB NVMe SSD | Intel AX200 Wifi (all-around awesome machine)
TrueNAS Server (Veda): Xeon E3-1241v3 | Supermicro X10SLL-F | Corsair H60 | 32GB Micron DDR3L ECC 1600MHz | 4x 10TB WD Whites / 4x 14TB Seagate Exos / 2x 1TB HGST 2.5" / 2x Samsung PM963a 960GB SSD / 1x Kingston 16GB SSD | Seasonic Prime Fanless 500W | Mellanox ConnectX-3 10G NIC | LSI 9207-8i HBA | Fractal Design Node 804 Case (side panels swapped to show off drives)
Media Center/Video Capture (Jesta Cannon): Ryzen 5 1600X | ASRock B450M Pro4 R2.0 | Noctua NH-L12S | 16GB Crucial DDR4 3200MT/s CAS-22 | EVGA GTX750Ti SC | UMIS NVMe SSD 256GB / Seagate 1.5TB HDD | Corsair CX450M | Hauppauge ImpactVCB-PCIe | Mellanox ConnectX-2 10G NIC | LG UH12NS30 BD-ROM | Silverstone Sugo SG-11 Case
Camera: Sony ɑ7II w/ Meike Grip | Sony SEL24240 | Samyang 35mm ƒ/2.8 | Sony SEL50F18F | Sony SEL2870 (kit lens) | PNY Elite Perfomance 512GB SDXC card
Network:
(500Mbps↑/500Mbps↓)        ┌─────────────── Office/Rack ──────────────────────────────────────────────────────────────────────────┐
Google Fiber Webpass ────── UniFi Security Gateway ─── UniFi Switch Flex XG ═╦╤╦═ Veda (general traffic)
╔════════════════════════════════════════════════════════════════════════════╝│╚═ Narrative (Asus 2.5G USB NIC)
║ ┌────── Closet ──────┐   ┌─────────────── Bedroom ─────────────────┐        └── UniFi Switch 8-60W ─┬─ Veda (management)
╚═ UniFi Switch Flex XG ═╤═ UniFi Switch Flex XG ═══╦═ Byarlant                                       └─ UniFi CloudKey Gen2 (PoE)
   (PoE)                 │                          ╚═ Jesta Cannon*
                         │ ┌─────────────── Media Center ──────────────────────────────────────────┐
Notes:                   └─ UniFi Switch 8 ─────────┬─ UniFi Access Point nanoHD (PoE)
═══ is Multi-Gigabit                                ├─ Sony Playstation 4
─── is Gigabit                                      ├─ Pioneer VSX-S520
* = cable passed to Bedroom from Media Center       ├─ Narrative** (Belkin USB-PD Ethernet Dongle)
** = cable passed from Media Center to Bedroom      └─ Work Laptop** (Startech USB-PD Dock)
Retired/Other:
Laptop (Rozen-Zulu): Sony VAIO VPCF13WFX | Core i7-740QM | 8GB Patriot DDR3 | GT 425M | Kingston 120GB SSD | Blu-ray Drive | Intel 7260 Wifi (lived a good life, retired with honor)
Testbed/Old Desktop (Kshatriya): Xeon X5470 @ 4.0GHz | ZALMAN CNPS9500 | Gigabyte EP45-UD3L | 8GB Nanya DDR2 400MHz | XFX HD6870 DD | OCZ Vertex 3 Max-IOPS 120GB | Corsair CX430M (?) | HooToo USB 3.0 PCIe Card | NZXT H230 Case (mostly intact, but some parts have been scavenged)
Parts: XFX RX 5600 XT THICC II | Mellanox ConnectX-3 10G NIC
No.
My monitor doesn't use AC.
19v:
12v
Then what is your actual part number? Because "ULTRAGEAR WK95U" only returns listings for "LG 34WK95U-W".
SPECIFICALLY, a USB-C output that supports USB-PD. Not every USB-C charger/device is PD compliant. And not every USB-PD device supports every PD level.
Network:
Retired/Other:
 Share
