Do I need more fans?
CiprianB
 Share
Hi,
I have a Corsair 7000d with an Arctic 420 AIO for the CPU. The cooling configuration is the following:
- AIO 3x140 mm fans exhaust on top of case
- 2x140 intake in front of the case
- 1x140 exhaust on the back of the case
Is this okay? It seems I have more exhaust (4x) than intake (2x)
Also, how does the GPU's 3 fans paly a role into this?
Should I get some more fans?
PS. Here's the full config:
- CPU: 7950x
- GPU: 4070 Ti
- AIO: Arctic Freezer II 420
- MB: x670e-f
- PSU: hx1000i
- Case: 7000d
- RAM: 2x32 DDR5-6000
- SSD: sn850x 2TB
Kind regards,
20 minutes ago, CiprianB said:
Hi,
- CPU: 7950x
- GPU: 4070 Ti
- MB: x670e-f
- PSU: hx1000i
- Case: 7000d
- SSD: sn850x 2TB
Kind regards,
I'd move the AIO to the front, and the other 3 stock fans as exhaust. If you have more exhaust than intake, you'll just pull in air and dust in through cracks (or where it can move the most free, like PCIe slots) and the CPU will not get hot air from the graphics card. The GPU won't change much in clock speeds and temperatures, since the radiator is so thin.
Have a look at this video and see top rad + open card and front rad + open card temperatures. (video starts comparing top radiator + open card and front radiator + open card) All temperatures at 12:08
Speaking from performance stand point, it should be fine, tho your case would have negative pressure, as in more air are being pulled instead of pushed. Which might affect the dustiness of your case, fine dust would get in easier than if it has more intakes.
Or just move the AIO to the front and configure as intake, then 3 exhausts.
Not an expert, just bored at work. Please quote me or mention me if you would like me to see your reply. **may edit my posts a few times after posting**
CPU: Intel i5-12400
GPU: Asus TUF RX 6800 XT OC
Mobo: Asus Prime B660M-A D4 WIFI
RAM: Team Delta TUF Alliance 2x8GB DDR4 3200MHz CL16
SSD: Team MP33 1TB
PSU: MSI MPG A850GF
Case: Phanteks Eclipse P360A
Cooler: ID-Cooling SE-234 ARGB
OS: Windows 11 Pro
Pcpartpicker: https://pcpartpicker.com/list/wnxDfv
Displays: Samsung Odyssey G5 S32AG50 32" 1440p 165hz | AOC 27G2E 27" 1080p 144hz
Laptop: ROG Strix Scar III G531GU Intel i5-9300H GTX 1660Ti Mobile| OS: Windows 10 Home
It's already pretty well ventilated, but negative pressure is bad for dust
Add a front intake fan to balance that
You can also play with fan speeds to have front fans running faster, back fan slower
System : AMD R9 5900X / X570 AORUS PRO/ 2x16GB Corsair Vengeance 3600CL18 / RTX3080 Gigabyte EAGLE GPU/ Phanteks P600S case / Customized Watercooling Eisbaer 280mm + Eiswolf2 360mm + VPP755 pump  and 150mm reservoir0.5TB Sabrent Rocket + 2TB WD SN850 NVme Gen4 + 4TB Toshiba X300 HDD drives/ Corsair RM850x PSU/ 34" 120Hz 3440x1440p Alienware AW3420DW monitor / Logitech G915TKL keyboard (wireless) / Logitech G PRO X Superlight mouse
The case hase the possibility to add further 1x140 intake in front and 3x120 near the front, on the side.
Shall I do that? Or shall I do that and move the AIO in front as well?
Or just move the AIO in front, as suggested and have 3 intake - 3 exhaust?
Kind regards,
 Share
