powersupply Is it ok to solder a different connector from a fan to another 4 pin fan?
Solved by 191x7,
There's one more thing to consider - PSU fans have variable fan speeds regulated by the 12V line - that means the fan you'd put ih nas to have a similar starting voltage as the one you're replacing. If the one inside starts at 5V and you put a fan that needs 8V to start, there's a chance the PSU will overheat.
Featured Topics
halfbood_drag0n ·
3
10
1
AcidVinyl ·
Posted in Graphics Cards3 -
Phantasmagoria ·
Posted in Cooling3
