The stock cooler is good enough. If you don't care too much about noise, you should be fine. I'd probably start with that (since it's free with the CPU) and then reassess based on how you feel about it.
If you don't like it, a basic tower cooler should be more than sufficient for the Ryzen 5 5600. Something like a Vetroo V5, Cooler Master Hyper 212, Thermalright Assassin X, or DeepCool Gammaxx would all be fine.
