Window tilling feature using in ubuntu
Solved by The Hope,
You are using Gnome. That's a standard desktop that isn't specifically aimed at auto-tiling windows.
You can install some tiling window managers with the following command
sudo apt-get install i3 dwm spectrwm stumpwm awesome
xmonad is also top notch, but you need to understand Haskell if you want to use it.
kisserik93 ·
Posted in Peripherals9 -
Rick13 ·
Posted in CPUs, Motherboards, and Memory12 -
6
popularlion ·
Posted in Troubleshooting5 -
2
CallMe_David ·
