I've looked, and so far unable to find that you can do it. But is there anyway to change the order of sound devices on win 10. I have a bunch of different devices i switch between but would love it if half of  them aren't at the bottom of the list. Ive disabled the ones i don't use but still have too many on the list due to certain softwares like GG creating virtual devices. Is there a way to re order them or am i stuck scrolling down each time i want to change devices?
https://linustechtips.com/topic/1484412-sound-devices-order-win-10/
I do not believe there is.
 CHRISTIAN MEMBER
6 minutes ago, Mark.S said:
i feared as much, its such a little thing but it feels like such an oversight that could be fixed with a little bit of effort. thanks
Well it's a very very very niche use case so it's not an oversight. Not that many people will have that many sound devices to completely fill up this menu. I'd say a very minuet fraction of a percentage.
Intel® Core™ i7-12700 | GIGABYTE B660 AORUS MASTER DDR4 | Gigabyte Radeon™ RX 6650 XT Gaming OC | 32GB Corsair Vengeance® RGB Pro SL DDR4 | Samsung 990 Pro 1TB | WD Green 1.5TB | Windows 11 Pro | NZXT H510 Flow White
Sony MDR-V250 | GNT-500 | Logitech G610 Orion Brown | Logitech G402 | Samsung C27JG5 | ASUS ProArt PA238QR
iPhone 12 Mini (iOS 18.3) | iPhone 15 (iOS 18.3.1) | KZ AZ09 Pro x KZ ZSN Pro X | Sennheiser HD450bt
Intel® Core™ i7-1265U | Kioxia KBG50ZNV512G | 16GB DDR4 | Windows 11 Enterprise | HP EliteBook 650 G9
Intel® Core™ i5-8520U | WD Blue M.2 250GB | 1TB Seagate FireCuda | 16GB DDR4 | Windows 11 Home | ASUS Vivobook 15
Intel® Core™ i7-3520M | GT 630M | 16 GB Corsair Vengeance® DDR3 |
Samsung 850 EVO 250GB | macOS Catalina | Lenovo IdeaPad P580
you may be right, but i found a bunch of posts asking the same thing, also thats not the menu that im looking to change. it actually looks like this and only fits 4 in the menu before you need to scroll.
Welp... score one for Windows 11 I guess. Seems to be room for 7 entries.
I have plenty of entries in mine but since I mix everything with Voicemeeter I never need to touch it.
F@H
GPD Win 2
