3 minutes ago, Matthew Graham said:
I’ve seen plenty 120mm and 140mm fans but are there any smaller sizes?
Yes, but the smaller you get, the louder they are.  It used to be they were almost always 80mm.
https://linustechtips.com/topic/1482099-case-fan-sizes/#findComment-15755931
Of course, those are just two sizes of many, what size do you need? 200mm? 180mm? 92mm? 80mm? 60mm? 40mm? There's tons of common sizes in various thicknesses. 80mm used to be the most common size.
https://linustechtips.com/topic/1482099-case-fan-sizes/#findComment-15755935
 Xi Jinping loves LTT (trust me).
Everything I say is true, unless it's false.
https://linustechtips.com/topic/1482099-case-fan-sizes/#findComment-15755939
8 minutes ago, andrewmp6 said:
I'd never want 80mms again they are loud and don't even move the same air a 140mm can.
I have a little 92mm 4000RPM ripper that blows as hard, or harder than a 140mm iPPC 3K 😄
It also removes flesh if you get too close, and it will blow your header if you hot plug it 🙂
AMD R9 9900X | Thermalright FW Pro Black, 3x TL-B12E | Asus Strix X670E -F | 64GB G.Skill 6000C26
Zotac 4070 Ti Trinity OC | WD SN850, SN850X, 2x SN770 | Seasonic Vertex GX-1000 | ProArt PA602
Adcom GFP-345, Adcom GFA-555, S.M.S.L D1+PS100, Cerwin-Vega! CLSC-15, Monster HDP-1800
https://linustechtips.com/topic/1482099-case-fan-sizes/#findComment-15757917
I had delta 80mms that was 4k i think.They cooled amazing but louder then a hair dryer on high.
https://linustechtips.com/topic/1482099-case-fan-sizes/#findComment-15757951
