Hello all.  I am rebuilding my pc and as it is set up on the left side of my desk.  as such, I was wondering if anyone had a suggestions for affordable inverted pc cases like the Darkflash dlv22.  I cannot find any for less than 200 bucks, or they are all sold out from any reputable vendors online.
It also needs to fit a 287mm GPU.
Should note, I have a asus tuf gaming wifi x570.  so the case would need to be compatible with an ATX Mobo.
https://linustechtips.com/topic/1481949-inverted-pc-case-for-my-setup/
Inverted setups are cool, mostly because you don’t see very many people run them anymore. My Stacker STC-T01 can do it. Just make sure you have good airflow. Running inverted may or may not have benefits for you, it really depends on your hardware selection.
AMD R9 9900X | Thermalright FW Pro Black, 3x TL-B12E | Asus Strix X670E -F | 64GB G.Skill 6000C26
Zotac 4070 Ti Trinity OC | WD SN850, SN850X, 2x SN770 | Seasonic Vertex GX-1000 | ProArt PA602
Adcom GFP-345, Adcom GFA-555, S.M.S.L D1+PS100, Cerwin-Vega! CLSC-15, Monster HDP-1800
Silverstone RL08, and LD01 are inverted. The LD01 is a bit harder to find, but in your budget,
The o11 Dynamic Evo pushes that $200 at $180, but also can be inverted.
Darkflash V22, but it's harder to find in the States.
The Silent Base 802 can be inverted and is probably the one I'd go with out of a lot of the inverted cases.
Project Hot Box
Oppbevaring
Why is the 5800x so hot?
